Hello Everyone!
A few week ago I was looking at this D.I.Y >> http://www.skylinesaustralia.com/forums/To...mp;hl=stop+beep in the hope of stopping my beep - but this method only seems to work on <R33. So I opened up my baby and had a crack - and I succeeded! Very easy - very quick - and no damage to anything - it's just a simple disconnecting of a plug :)
I have Found no Side effects to any other system - I have a Auto Watch emob. and it still works fine - also this will not get rid of the beep for when you leave your lights on and open your door - also does not effect the door open lights on/off function
What you need:
RATCHET
10mm Socket
Phillips Head Screw Driver
Your Keys! <you will see why ;)
(Next 2 items are handy to have close if needed - but not essential)
Flat Head screw Driver (with double sided stick tape with one side still covered with plastic wrapping to stop sticking) < I use this to wedge open anything that is hard to open up - the double sticky tape prevents scratching because its spongy - very useful for when you need to take out air con vents on the R34 etc. as well.
And my trusty Victorinox Swiss Army Knife :)
(CLICK ON PHOTOS FOR LARGE PICTURE)
Step 1: Unscrew Lower cover
Left Hand Side of Lower Panel (Phillips head screw driver)
Right Hand Side of Lower Panel (you will need 10mm socket)
Here you will have to disconnect all Wires and thread them through any holes so you can remove the whole cover and put it out of the way
Step 2: Unscrew Steering wheel under cover
Open the Steering Wheel Adjustment Leave Right out so that it doesn't get in your way - also so that you can move the steering wheel up and down to help wiggle the case off
Step 3: Remove the demand Beeperiser Plug
Your Undercover should look like this now - if not - you have gone astray and need to revert back to step 1 and/or you have the wrong car and revert back to top link!
See that white plug well - Now you hear it!!
Now you don't!! - Now just rap that sucker around some wires and make sure the little slider inside the plug is OFF - this is what your keys are for!! Before you go and put it all back together put the key in and make sure it is in the off position otherwise it will forever be beeping :(
Enjoy the sweet sweet sound of beeplessness ;) and your stereo when you want to work on your car :)
If you need any help just post or Pm me :)
Aron
https://www.sau.com.au/forums/topic/242701-diy-stop-open-door-beep-for-r34/
  • 4 weeks later...
Legend :)
Will try that out in the weekend. Main motivation being the ability to listen to the stereo at low volume while working on the car...high volume kills the battery and low volume gets killed by the BEEP.
Was this trial and error for you? with all the tips involved you would tend to think so hehe..
Thanks again
  • 1 month later...
Cool thanks i just did it!!!! fantastic!
U don't need to remove the lower panels - only the steering wheel cover
Just remove the steering wheel panel (Start from STEP 2), to get to the white connector and disconnect it. Only need a philips screwdriver for the job.
Im Pretty sure jaycar have a kit that will have your lights work like normal (ie. still turn on without key) but turn off when you take out the key after driving, much like a commodore. Dont quote me on it thought, definantly somthing useful however.
  • 4 months later...
  • 2 months later...
  mrRS4 said:
Will this get rid of the annoying beeping sound when your car is in reverse?
Nope, i don't spend much time in reverse so it doesn't bother me that much. But if you do want to remove it i cant imagine it would be very hard....just find the beeper and cut the wire...
  • 5 weeks later...
  • 4 years later...
Anyone have any clue which plug I'm looking for? Pics above don't work and I've tried a few white plugs but none of them are turning the beep off. Here's a pic from under the steering column.
Too late to edit previous post, I had only tried a few plugs cause I was too scared of unplugging the airbag. Eventually worked out the airbag is the bright yellow plug so I got more adventurous with the white plugs.
The plug that controls the key-in-ignition signal is a T shape white plug on the underside of the ignition barrel. It looks like the photo below when unplugged. You can unplug the white end or the other end (small brown connector above ignition barrel) with the same result:- no ignition + open door beep, keep headlights + open door beep.
