Hi all , if you become a Garrett Gearhead (apply at their turbobygarrett site) you get tech updates from time to time .
In the pipe as they say .
Briefly they say that people are getting stuck between the choice of GT3582R or GT4088R , they say people want the response of the GT3582R with the power of the GT4088R .
Their answer is to use a GT37 turbine in a GT4088R making it a GT3788R , they mention that it will be available in three turbine housing sizes and my guess is they will use three of the four castings normally used on a GT4088R ie 0.85/0.95 1.06 and I think 1.12 . Fingers crossed the turbine will be a petrol spec (high temp material) UHP (Ultra High Pressure Ratio
version because this will span the gap between the GT35 UHP turbine and the GT40 UHP one . I can see it making the old T4 P trim turbine redundant (ie T04Z turbine) if they do .
The burning question will be what trim this turbine will have , fingers crossed it will be 78 trim like the GT40 UHP turbine and not 84T like GT30/35 plain bearing GT40/GT42 etc .
They mentioned that the power range (IMO depending on turbine housuing A/R) is 440 to 675 - which is really GT3076R to a bit above what single scroll GT3582R territory .
I think all these housings are twin scroll T4 flanged - perfect for those HKS low cast RB26 exhaust manifolds .
The second turbo to rate a mention is their GT3582R , in their wisdom they have decided to make available port shrouded compressor housings and a few more turbine housing options . Port shrouded comp housings let you get away with smaller A/R turbine housings without surge . Note HKS do it to 2835 Pro S turbos and RB spec GTRS's (GT2871R 52T) .
They look like making the GT35R T3 flanged housings with V band outlets and a T4 flanged version with a four bolt outlet . They don't specifically mention single or twin scroll with these but the info will get out in short order if the turbo spies around the world have their way .
The Evo Lancer crowd look like getting bolt on versions of the GT3071R and GT3076R , I reckon to make them work they'd have to be reverse rotation . Fingers crossed Garrett will continue on with the twin scroll twin flap valve gates like the factory reverse rotation Mitsubishi turbos have . From memory Evos 4 to 10 have them and the only single scroll ones will be the pov pac Ralli Art Lancer to be released soon - to compete with non STi Ram Raiders .
No idea when , cheers A .
https://www.sau.com.au/forums/topic/242705-new-things-on-the-way-from-garrett/
I guess it would depend on who supplied it and if they cut costs by not using a genuine Garrett GT35 turbine housing .
I think one mob in the States may have been machining the "ears" off Garrett housings to form a V band flange .
Also you see them on US sites with what looks like T3 flanged TB31 turbine housings on them .
I would always prefer a Garrett housing designed for the turbine size and family used .
A .
A .
its a genuine garrett housing, came from MTQ
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
