JZX100 Chaser
Wheel Base: 2730
Exterior Dimensions: 4715x1755x1400
Curb Weight: 1470Kgs
R33 GTS25T Type M
Wheel Base: 2720
Exterior Dimensions: 4640x1720x1340
Curb Weight: 1370Kgs
My car is 7.5cm longer 3.5cm wider and 6cm higher, not bad considering my car is a 4 door family car and the 33 is a 2 door SPORTS car
also, i never said my car wasnt a whale, i just said that the 33 was :D
Edited by Ex!$t3nZ
  • Replies 181
Posted Images
I'm cutting it fine.... I've been told Friday or Monday for the car with the hope for Friday cause they know that I have a Skyline cruise on the weekend...
Gonna be a cranky pants if I can't go in my car!!!
it's a couple of pages back but
Meeting Museum: 12:30 this sunday Leave by 1pm.
Go For a bit of a drive coppins crossing etc. before stopping at cotter BBQ area for lunch ($2 Donation to Shell)
Then after BBQ, Cruise tharwa way for those who are keen ending at point hut crossing.
Note: CB Radio comes in handy so if you got one bring it :bunny:
Cheer Cheer :blush:
Sunday Fine, mostly sunny. Min 8 Max 24
http://www.bom.gov.au/products/IDN10035.shtml
perfect weather for the day!!! Should be good I can't wait personally :)
Wooooo!!! Photos :P:) SOooo pumped cant wait!!!! ;) Ahhh Reese you need to show me how to get to the museum, i went there on the weekend but didnt drive and was morphiened up soooo cant remember becuase things were preety groggy :)
i wouldn't mind some pics with yours and my car actually they look quite similar you definitly beat me for pink factor (thank god) though lol
if you a south sider I can met you beforehand and show you to the museum
Edited by Darkon
well melly sounds like you got another partner lol if you two meet up ill go wash my car and cath you guys at the meeting spot.
i'm sure ill talk to you be4 then.
looking forward to it should be a good day..
:bunny::bunny::bunny:
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
