  • Replies 181
Posted Images
1. Shell
2. Darkon
3. Kat
4. Turismo
5. ZCR
6. Sinista
7. Michele & Mark
8.race_snooze
9.zZzDanzZz
10.MIVEC
11.MANG
12. Frink
14. sl33py (it's on purpose!)
15. SteadyEddie
16. Melly & Reese (dont know his forum name haha i forget it)
MY BABY IS HERE!!!! FINALLY!!! over 12 months without her and now i am driving again >_< Wave if you see my pink girl driving around :)
1. Shell - bell
2. Darkon - sharkon
3. Kat - dog
4. Turismo - grand
5. ZCR - ABC
6. Sinista - Angle
7. Michele & Mark - will beat me & with a stick
8. race_snooze - Daily_Awake
9. zZzDanzZz - zZzBanzZz
10. MIVEC - V-TEC
11. MANG - Nang
12. Frink - Professor
14. sl33py (it's on purpose!) - No its not!
15. SteadyEddie - UnsteadyChampion
16. Melly & Reese (dont know his forum name haha i forget it) - Smelly & Pieces
17. Driftgts & Siren - Rules & nothing rhymes (Cryin?)
lack of car and family committments. Might take you up on it if circumstances change.
No worries matey let me know.
I should be picking up your wheels on Saturday so will drop those off to you in the next week or two :D
1. Shell - bell
2. Darkon - sharkon
3. Kat - dog
4. Turismo - grand
5. ZCR - ABC
6. Sinista - Angle
10. MIVEC - V-TEC
11. MANG - Nang
16. Melly & Reese (dont know his forum name haha i forget it) - Smelly & Pieces haha... i'm (reese) sexy33 i'm in for the cruise
:/:) Not cool..... My R33 is sexy!!! and NOT a whale.... Hmmmph!!
Even tho I LOVE the r33, I also like the r32 and r34.... They all have different qualities that I appreciate :(
No.
Back in your box James:P
As for cruise route, how about this year we skip the straight-to part and take the nice twisties that starts off Coppins Crossing road off of William Hovel Dr?
Then those who want can go home via the normal Cotter road while us Southies can continue on South to Tharwa and then go home that way.
you have a very good point miss melly! :bunny:
second that
southside for life bro!! hahaha
:down::ermm: Not cool..... My R33 is sexy!!! and NOT a whale.... Hmmmph!!
Even tho I LOVE the r33, I also like the r32 and r34.... They all have different qualities that I appreciate :D
well free willy was sexy too but come on.. you gotta draw the line somewhere
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
