  • Replies 181
Posted Images
Sounds like a Southside meetup and cruise to Museum. We should do a drive-by Richard/Sinista so he doesn't get a dose of that Weak Sauce too (more like p!ss weak sauce).
I haven't heard from Brendan Donnan... whats up!!!!
Jayce - You joining us?
I still dunno what we'll be driving but we'll be there for sure. Everyone cross their fingers for a shiny white GTR!!!!!!
I did tell Ed that I'd cry if I didn't have it but I'd still rather they not rush it.
yeah got back in on sunday
What ya reckon I'll meet you at the servo near indoor sports kambah at 12 on sunday?
Yeah sounds good... Reese we will do the cars at urs as organised yesterday and then cruise there to meet up with Darkon :blush::D
sorted see ya's there.
Just need some where to give my car a quick clean now ;)
yeah no worries, wat 12 oclock at kambar indoor sports centre?? then i can sleep in till 10 ;) if im aloud lol
Shell I'm sure if you rock up at 12 (maybe walk down?) I'm sure one of us will be able to give you a lift.
Shells doing bbq stuffies, she will have too much stuff to walk anywhere... wanna be picked up Shell?
I'll get Shawn & Simon to grab me, Simon knows where I live so its easy ;)
sorted will be there about 1145
god love timings
1145 shells
1200 met servo
1230 met museum
1300 leave museum
driving a skyline...
priceless :)
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
