The following is the proposed calendar for 2009. Any changes will be notified during the year.
The Time Attack Series is points based so all participants are welcome, even if you are not contending the championship.
I have made the morning session of every track day our normal sprint event. Beginners are welcome to come and get involved. I will continue to run the beginners group in 2009.
Summary of Events at Qld Raceway (Lakeside TBA)
Time Attack Series: 6 Rounds
Street Car Shoot Out Series: 3 Rounds
Nissan Day: 1 event
EVO Day: 1 Event
TUESDAY JAN 27
Morning: Normal Time Attack Sprints
Afternoon: Time Attack Series Round 1
TUESDAY FEB 24
Afternoon: Time Attack Series Round 2
TUESDAY MARCH 24
Afternoon: Street Car Shoot Out Series Round 1
THURSDAY APRIL 23
Afternoon: Time Attack Series Round 3
TUESDAY MAY 19
Afternoon: Time Attack Series Round 4
THURSDAY JUNE 18
Afternoon: Street Car Shoot Out Series Round 2
WEDNESDAY JULY 15
Afternoon: EVO State of Garagin
FRIDAY AUGUST 14
Afternoon: Time Attack Series Round 5
THURSDAY SEPT 17
All Day: NISSAN EVENT
TUESDAY OCT 27
Afternoon: Street Car Shoot Out Series Round 3
TUESDAY NOV 24
Afternoon: Time Attack Series Round 6
https://www.sau.com.au/forums/topic/242762-2009-time-attack-calendar/
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
