The following is the proposed calendar for 2009. Any changes will be notified during the year.
The Time Attack Series is points based so all participants are welcome, even if you are not contending the championship.
I have made the morning session of every track day our normal sprint event. Beginners are welcome to come and get involved. I will continue to run the beginners group in 2009.
Summary of Events at Qld Raceway (Lakeside TBA)
Time Attack Series: 6 Rounds
Street Car Shoot Out Series: 3 Rounds
Nissan Day: 1 event
EVO Day: 1 Event
TUESDAY JAN 27
Morning: Normal Time Attack Sprints
Afternoon: Time Attack Series Round 1
TUESDAY FEB 24
Afternoon: Time Attack Series Round 2
TUESDAY MARCH 24
Afternoon: Street Car Shoot Out Series Round 1
THURSDAY APRIL 23
Afternoon: Time Attack Series Round 3
TUESDAY MAY 19
Afternoon: Time Attack Series Round 4
THURSDAY JUNE 18
Afternoon: Street Car Shoot Out Series Round 2
WEDNESDAY JULY 15
Afternoon: EVO State of Garagin
FRIDAY AUGUST 14
Afternoon: Time Attack Series Round 5
THURSDAY SEPT 17
All Day: NISSAN EVENT
TUESDAY OCT 27
Afternoon: Street Car Shoot Out Series Round 3
TUESDAY NOV 24
Afternoon: Time Attack Series Round 6
https://www.sau.com.au/forums/topic/242762-2009-time-attack-calendar/
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
