  • 4 weeks later...
clutch type diffs need an LSD oil. The standard R33 diff does not need an LSD oil because the viscous centre is a sealed unit.
LSD oil has friction modifiers so the wet clutch works properly, if you fill with a normal oil your diff will shudder.
Check to see if that Castrol one is suitable for limited slip differentials.
Hard to get, not even sure what grade or weight, I'd need the brand grade and weight first. ie Motul Gear Oil 90 PA SAE90 or Motul Gear Competition 75W140????
I'm thinking that the Gear Competition would be the go, but would like to be sure, tearing the teeth off a diff is NOT on my list of things to do..........lol
  • 2 years later...
Can anyone tell me the capacity of a Nismo diff.
A std diff is 1.8 litres, i just did my Nismo and it only took 1.35 litres and thats after I double checked!!
It flowed out the fill hole twice so it has to be full, but I'd like to have my figures confirmed - peace of mind and all that.
Since when is a std diff 1.8? 1.3 is on the money unless you have an extended backing plate (trust)
80-250 doesn't sound right, didn't think you could get the viscosities that far apart in an oil??? Maybe 80w150????
http://www.otomoto.com.au/osgiken/superlock.htm
have a look at that... ( i double checked too.. i did read it correctly!) lol
Sorry, i went off what a certain well respected shop told me when they looked it up - when i was buying the oil.... pretty sure they said 1.8 - but it could be my memory, maybe they said 1.3 - I can't be 100% sure. Then I didn't look it up anywhere to check either.
BTW I just did a 1500km weekend and the Motul Gear Competition 75W140 worked fine, no problems.
And EJD, apologies, 80w250 it is>>>sounds like a good broad viscocity base, would handle a lot of situations.
  • 2 months later...
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
