  • 4 weeks later...
clutch type diffs need an LSD oil. The standard R33 diff does not need an LSD oil because the viscous centre is a sealed unit.
LSD oil has friction modifiers so the wet clutch works properly, if you fill with a normal oil your diff will shudder.
Check to see if that Castrol one is suitable for limited slip differentials.
Hard to get, not even sure what grade or weight, I'd need the brand grade and weight first. ie Motul Gear Oil 90 PA SAE90 or Motul Gear Competition 75W140????
I'm thinking that the Gear Competition would be the go, but would like to be sure, tearing the teeth off a diff is NOT on my list of things to do..........lol
  • 2 years later...
Can anyone tell me the capacity of a Nismo diff.
A std diff is 1.8 litres, i just did my Nismo and it only took 1.35 litres and thats after I double checked!!
It flowed out the fill hole twice so it has to be full, but I'd like to have my figures confirmed - peace of mind and all that.
Since when is a std diff 1.8? 1.3 is on the money unless you have an extended backing plate (trust)
80-250 doesn't sound right, didn't think you could get the viscosities that far apart in an oil??? Maybe 80w150????
http://www.otomoto.com.au/osgiken/superlock.htm
have a look at that... ( i double checked too.. i did read it correctly!) lol
Sorry, i went off what a certain well respected shop told me when they looked it up - when i was buying the oil.... pretty sure they said 1.8 - but it could be my memory, maybe they said 1.3 - I can't be 100% sure. Then I didn't look it up anywhere to check either.
BTW I just did a 1500km weekend and the Motul Gear Competition 75W140 worked fine, no problems.
And EJD, apologies, 80w250 it is>>>sounds like a good broad viscocity base, would handle a lot of situations.
  • 2 months later...
    • My son has an R34 gt auto. I'm looking at methods on how to tune it with the view to be able to further tune it down the track when he is off his P,a and can go turbo. The issue is the 98 gt auto has a seperate TCM and is not compatible with swapping out a gtt auto nistuned pcm ( from what I have read so far ) Please if anyone has info on what to do here I would much appreciate. Realise that some options include manual swap, manualised valve body. Just hoping there is a more direct running option I haven't been able to find. Thanks in advance.
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
