Hey guys I was having some problems with my car pinging it turned out that the crank angle sensor was not in the right position(dam mechanic). I moved it clockwise a few weeks ago(retard) and the pining has stoped so far. how ever the car just wasn't running the same, so today I turned it back slightly still not where it was when it was pingping but just a few mil back. now on my safc I'm getting a knock reading of 60-80 while the car is at idle. I went for a drive and put the foot down a little and couldn't hear any ping and the knock level slowly droped thru the rev range down to about 0-10. should I be concerned about this high number at idle? or should I just reset the knock value as the timming has been changed? when I went in to sensor check idle knock was at 320-330? is that high?
Cheers
Russ
https://www.sau.com.au/forums/topic/242804-about-knock-help-please/
5 at idle is fine; mine's on about 4 and goes up to about 7-9 when i give it a bit of a rev.
Was your first post clear? cos you said 60-80 then 320-330; somethings not right there.
When you start your car from cold does it register a high knock?? cos mine knocks to 93-95 while cranking and thats even when ive disconnected the coil-packs.
like nismoid said; may be something in the engine bay or a stuffed sensor even the starter motor.
