hi all, after recently being harassed by my friendly local hwp officer, and listening to some hoo hah about how modified cars make baby jesus cry, it seems i have maybe 2 weeks to do something about my atmo bov and pod filter. or risk being headhunted further.
atmo bovs may be illegal, despite them sounding awesome, but what i need to know is what i can do about it exactly. the car is pretty heavily modified as you will see from the photos, and im pretty sure i cant get away with a stock bov (as if it could handle 18psi anyway). so what options do i have?
- use hose fittings to plumb a hose from the bov back into the intake somewhere? will that make it much quieter? the horn section unscrews, and i think id be able to screw in a hose fitting fairly easily.
- block it off? i expect this defeats the purpose of a bov completely.
- replace with some kind of aftermarket plumb back bov?
also, will a black plastic enclosure around the pod filter keep the nathan rees and co. at bay?
thanks guys
ps: no i dont deserve to be harassed, i only have one speeding fine on my record and even that was highly dubious and the police offered me a reduction to <15kmh in court.
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/
im taking the punt and attempting to fabricate a cover for both the pod and the bov, looking for black plastic so it looks factory-ish. im going to paint the bov black, so even if you look really hard you wont be able to make anything out under the cover.
would they defect me just by hearing the noise? even if they couldnt find the damn thing in the engine bay? (obviously i take care not to blast it whenever i get a whiff of porky pig in the air)
i guess i can plumb it back, its just a bit of a hassle, and i love bov.
You can make your own like mine, hopefully mines all good :D
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4254764
Even with my factory bov, it sounds like I have an aftermarket one because it goes back through the pod and makes the noise.
So dont know if they can just for the noise...it'll make them look though :D
Im thinking of painting my airbox black so it looks like it would fit in.. haha
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4254801
jsai does n off the shelf type air box not too expensive.Ive got one on my gtr n when i was gettin defected the coppas smile soon went from big to non existant when they lifted my bonnet.I got 2 pods n a blow off valve lol coppas they should be chasing real crims
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4254851
yeh trouble is, my intake setup is rather unique. theres custom piping out of the turbo, and the bov is right next to the afm etc. i will have to fabricate something unfortunately.
i look forward to their disappointment. my mate suggested putting a cover on the whole engine bay! i wonder how that would go down... assuming youd maintain adequate ventilation.
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4254861
I've often thought of doing the exact same thing... Or at least making an "engine" cover up that spanned out across the engine bay... Couldn't do shit then...
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4255245
As far as I'm aware your best off making your pod cover out of aliminium. as it works well as a heat shield from the engine heat. Colder the air the better.
That's what I did with mine anyway.
https://www.sau.com.au/forums/topic/242807-hwp-nightmare/#findComment-4256396
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
    • I was just going to replace the fuel line and keep the stock one, but they do look pretty nice lol.
    • Are you going to delete the stock damper or are you just replacing the fuel lines and keeping the stock damper?  There are also options for sexy ones if the stock one is too ugly for you lol -  https://www.radiumauto.com/Fuel-Pulse-Damper-Inline-Kits-P751.aspx or https://www.radiumauto.com/Fuel-Pulse-Damper-Direct-Mount-Kits-P759.aspx So sexy.
    • I think you guys are right. The only reason I thought it was a restrictor was I had seen the same yellow band on the r32 boost restrictor. Will just replace with a standard fuel hose. Thank you for your speedy replies. I'm sure I'll have many other silly questions.
