Qld: Shed Clean Out, All Parts Gotta Go!
alrighty guys, i got heaps of stuff that needs to go as i no longer need these parts.
heres the list so far, will get pics on request
RB25 head with 62,473 genuine km's, seen the car it came out of. Head comes complete with loom, AFM, igniter with ford falcon coil set up or if u want orginal coils can organise that instead of falcon coils, coilpack center cover, inlet manifold with all sensors and injectors, Genuine manual Mines ECU, rocker covers fully polished, and AFM no exhuast manifold but i have a RB20 turbo complete setup with lines and all which could be used with the 25 head - asking $800 for the the lot without the RB20 turbo and manifold or $900 all together
LOOMS-
RB20det redtop - $80
RB20det silvertop - $120
RB25det - $120
RB20DET silvertop manual ECU - $150
RB20DET redtop manual ECU - $100
RB30E manual ECU - $50
RB20DET silvertop turbo setup with all lines, banjo bolts, washers, manifold, elbow and wastegate actuator VGC $250
RB20DET silvertop turbo with lines and wastegate actuator only GC - $150
RB20DET silvertop inlet manifold with all sensors and injectors VGC - $80
RB20DET silvertop coilpack cover - $40
RB20DET silvertop cam cover - $20
RB20DET rocker covers - $40
RB25DET pistons, rods, crank and crank cradle (came out of the low k motor mentioned above) block was sold to a mate - $250 all items are like brand new
RB25DET alternator - $80
7MGTE auto ecu- $60
Custom Zub zero polished turbo, biggest TO4 compressor housing with a T3 flange (not sure of exhaust AR) comes with staniless steel manifold and garret wastegate with screamer pipe in good condition - $700 ono
RB20det manual gearbox - $400 ono
RB30E manual gearbox conversion out of R31 with tailshaft, cluch and brake pedals, slave cylinder, master cylinder, line that runs to slave, shifter, crossmember, clutch fork, thowout bearing, flywheel, clutch and pressure plate - $650
R31 S3 tail light center garnish and bottom tail light surrounds - $80
various BOV's $50 each
RB20/25det crossover pipe with plumback BOV - $50 each
RB20/25det rubber elbow that joins to compressor on turbo - $20 each
RB20 AFM's $60 each
RB20 and 25 coilpacks - $20 each or $110 for 6 with coil adaption plates
RB26 Twin 600hp Nismos complete with all lines banjo bolts, wahsers, all intake piping with rubbers, actuators, dump pipes, oxy sensors, and both manifolds. 1 of them in in mint conditon the other has a little of horizontal play, all fins on compressor wheels are mint - $1300
1984 toyota 4runner in good condition with a V6 commodore engine in it, mated up to a surf gearbox which is the same a supra box but with a transfercase, car has been mod plated, was registered but just ran out. Heads were just done on motor, various gagues oil, water temp, volt gauge, CB radio, kenwood cd player with 6x9's car was sanded back to bare metal and resprayed in acrylic yellow ( standard colour) no rust in it, side steps, Bull bar, 2 spot lights, auxilary tank. not much needed to get a legit roadworthy just needs two $5 axle seals, 2 front seats and a drivers side window winding mechanisim. Tough Fourbie chasing $4000 ono
2001 KTM 250SX New pistons and rings, new rear suspension, new rear pirelli tyre, new front shocks but one recently blew a seal, pro circuit expansion chamber and muffler. Very fast bike not for faint hearted $3800 ono also comes with different colour plastics and a rear fender with tail light
OR $7000 for both the fourbie and the dirt bike.
THATS ALL FOR NOW, WILL GET PICS ON REQUEST AND I WILL LIST MORE PARTS SOON!
THANX GUYS FOR TAKING THE TIME TO CHECK THE AD OUT
CALL ME PLEASE IF UR KEEN ON ANYTHING ON 0401366024 I DONT USE THE NET MUCH SO YEAH, PLEASE CALL
CHEERS,
IVAN.
 Share
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
