Finally got the R32 25de head back from Cylinder Head Specialists and its almost time to put it onto the block.
BUT it's not at 1tdc and I dont have a workshop manual. Does anyone have a link or an answer to setting the shafts plus angle sensor up correctly? I know the timing is about 15 degrees before tdc on idle but its not ready to start yet and i dont want any bent valves or teeth marks in this pistons!
Any help would be awesome.
Cheers in advance.
xsv_32
https://www.sau.com.au/forums/topic/242820-head-assembly/
When you put the cam gears on, they'll have a marking on them that will align to the backing plate.
Set them to that.
Then, the crank pulley as a mark on it, that aligns to a notch, align it to that.
Put the timing belt on, crank motor over 2 full turns of the crank by hand, inspect these 3 markings still align properly. If they don't redo them.
https://www.sau.com.au/forums/topic/242820-head-assembly/#findComment-4235959
Set them to that.
Mint. Thanks for that, the guy i bought the hear off has left white marks that look like th 15 degrees. Will clean them off and see if theres a mark underneath them.
One last thing, my head gasket is for a GTR, 87mm bore and 1.3mm thick. Everything lined up except for the triangle shaped water galleries between each cylinder on the intake side. the gasket has circles instead but dont think this will efect anything.????
https://www.sau.com.au/forums/topic/242820-head-assembly/#findComment-4237719
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
