Hmmm. Went for a dyno test and my car only got 156.3hp at the wheels. Never seen a graph like this before. Fully stock engine except for a FMIC. The mechanic said that my engine is running LEAN and that there is more air than fuel. He suggested that i change the fuel pump. My current fuel pump is working and spraying lots of fuel when ignition is switched "ON". I wanted to be sure that's it's the fuel pump as that costs like over $400 new here. So any suggestions?
And one more thing, can someone tell me how to read this dyno chart. I'm lost but i do know that the line shouldn't go back to the vertical one.
Edited by teng
https://www.sau.com.au/forums/topic/242881-running-lean/
  • 1 month later...
Thanks to information contributed by some of the SAU members through PM and the information i got from the SAU forums, i got the lean and boost problem sorted out. Bought a NISMO 4.1L Fuel Pump to fix the Running Lean problem and a HKS Adjustable Actuator to fix the low boost problem. The Actuator is set at 0.6bar at the moment. I also bought the Adjustable Fuel pressure regulator but didn't get to use it.
Dyno results;
204.2hp @ the wheels
250.7hp @ the flywheel
Not bad considering it still has stock internals, stock turbo & stock injectors.
The stock turbo holds boost well at 0.6bar and can hear it spooling at around 2000rpm.
The one thing i do notice is that my fuel economy has risen. Before the problem was fixed, i can only get 300km. Now i can get over 400km to a tank which is a very good improvement.
Edited by teng
https://www.sau.com.au/forums/topic/242881-running-lean/#findComment-4336718
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
