Midnight Express
We are using this thread to display the progress to our demo car that will showcase new parts for R33's and various other RB parts. We welcome all comments and constructive criticism. The aim of this project car is to have achievable results that most people can do to their own vehicle. We believe that having a demo car that is so far away from a daily street registrable, although looks good, misses the point of a demo car. If there are any things you would like us to cover in this thread by all means let us know.
This thread is replicated in a more formal way on our website, of which we will try to update as often as possible. Be aware that this car resides in NSW however our business is based in Melbourne. Occasionaly the car is transported to Melbourne for various events, otherwise can be see at various SAU NSW club meets and track days.
The story thus far...
We searched far and wide for a car that is common among tuners of today, that has a very reliable base to work with and also takes well to modifications. No real surprises here, we ended up looking for a clean Nissan Skyline R33. As there are many different models to choose from we decided on getting the somewhat rare 1998 40th Anniversary Model. These are often sold for more than a standard M Spec. The main attraction drawing us to this model was the lovely hues of the Midnight Purple duco and the factory options available to it.
The 40th Anniversary editions had some differences over other models, those being:
Standard Features
Badge on the seat
Badge on C pillar
Uses NEO spec engine parts
- CAS (Crank Angle Sensor)
- Cams use different key
Front & rear strut braces with Nissan logo
Made in late months of 1997 or 1998
Limited Slip Differential
Factory Options
Additional colour codes - e.g. Midnight Purple
Momo with airbag
GTR Spoiler
GTR Bodykit
Satellite Navigation
6 CD Stacker
We eventually found the car we were after and purchased it for the reasonable asking price of $15,700. This included the modifications required to meet ADR (Australian Design Rules). The car itself had a few extra goodies as well like; Tein HR Coilovers, SatNav, CD Stacker, Genuine GP Sports Front Bar and Side Skirts and a 3" HKS Exhaust.
After taking possession in mid January 2007 came the lengthy and frustrating task of Registration in NSW. Now most cars are simple enough to register however many of you can probably sympathise with the difficulties faced by Import owners. Upon returning the car back to almost factory condition it was then sent to get a Blue Slip, Green Slip and a compulsory further inspection. Once this had all been done we are then required to go back to the RTA and fill out the remaining paperwork and get the cars plates.
Now that all the legalities are taken care of it can be driven on the street and the planning process for modifications can begin. As with any high performance car it will need intuitive thinking along with a sound knowledge of both the cars characteristics and engine strengths to achieve a good result. As the car will be used mainly for street and circuit, with some show events and lmited strip time, this will greatly influence the path this vehicle takes.
We will be documenting each modification step and provide feedback on any decisions that had to be made. Where possible we wish to provide a dyno sheet, non-bias judgement or technical report to evaluate the work we carried out.
Pictures of our Project Car (aka Midnight Express) when we purchased it:
Current Specs
Haltech E11v2 ECU
Haltech R33 Loom Adaptor
Haltech Air Temp Sensor
Haltech 3 Bar MAP Sensor
Haltech Racepak Digital Logging Dash
GReddy Turbo Timer
GReddy Profec B Spec-II Boost Controller
GReddy Oil Filter
GReddy Plenum
GReddy Adjustable cam sprocket - ex
GReddy Oil Fill Cap
GReddy Catch Tank
GReddy Timing Belt
GReddy Type S Coilovers
GReddy PE II Exhaust
GReddy Spec-M Universal Inercooler
GReddy Strut Brace
GReddy RS BOV
GReddy Radiator and cap
GReddy Type M Filter M100
GReddy Fuel Rail (11mm)
GReddy Injectors 720cc
GReddy Oil Cooler and Filter Relocation Kit
Sniper Racing Clear Cam Gear Cover
Sniper Racing Carbon Sill Plates
Sniper Racing Carbon GTR Wing End Plates
Sniper Racing Carbon GTR Wing Blade
Nissan Q45 90mm Throttlebody
Whiteline Front Sway Bar
Whiteline Rear Sway Bar
Whiteline Front Camber Kit
Garrett Custom Turbo
Tomei Poncam Camshafts
Bride Ergo II Seats
Bride Seat Rails
C's Short Shifter
Custom Fuse Box Cover
Sharp Reverse Camera - Hooked up to Pioneer screen
Custom Carbon Shift Knob
Sard Fuel Pressure Reg
Bosch 044 Fuel Pump
Custom Surge Tank
Custom Fuel Pump Bracket
Custom Braided Brake Lines
EBC Red Stuff Pads Front and Rear
RDA Turbo Groove Rotors Front and Rear
R33 GTR Brembo Calipers
Pioneer F900-BT AVIC Head Unit
Pioneer Splits in Front Doors and Parcel Shelf
https://www.sau.com.au/forums/topic/242907-psi-parts-project-car-log/
  • Replies 90
After much discussion about what kit we would put on our project car, we went with:
R33 GTR Do Luck Front Bar to fit GTS
R33 GTR Do Luck Rear Bar to fit GTS
R33 GTS Do Luck Side Skirts
As the car had a few scratches and slight dints we decided to give the car a full re-spray which included removing the front and rear windscreens, with the front windscreen being replaced completely due to a small stone chip. The colour would be the same factory paint, Midnight Purple 1 (LP2).
As with our RX7 FC Project Car the respray job was sent to Andrew, thus we use and recommend:
C & A Superfinish
3 James Street
Clayton South VIC 3169
Ph: (03) 6544 4565
Please tell them PSI Parts sent you
We had the opportunity to make a few little changes to the car with the full respray and thus we decided to give the car a genuine GTR Rear Wing, remove the boot lock and replace with the rear view camera, brand new 40th anniversary badges and paint as much of the engine bay as possible without removing the engine.
Here are a few pictures of the car during it's time getting resprayed. You will note that the front bar was modified due to the adjustable suspension has pushed the front wheels forward for greater steering response, other than that the kit fit extremely well.
should of used a complete gtr front end to give it more of an aggressive/ bulkier look
We think the Front bar gives the car an aggressive enough look as it is (with the possibility of the Blazer CF Hood to come) and we didn't want to change the car into a GTR look-a-like either :ermm:
  • 1 month later...
lol i thought i knew PSI parts from somewhere, you guys are a few factories up from me, and everytime i drive passed i think 'where the hell do i recognize that name from'
that r33 really does looks good in real life too
  • 4 weeks later...
  • 4 weeks later...
I'll be off the forums for a few months as I'm heading overseas. Shane will take the over therefore any enquiries it's best to contact him via email [email protected], as he doesn't have time to check multiple threads. We appreciate your feedback and upon my return I'm looking forward to introducing a whole range of new parts.
The car has seen quite a lot of changes since my last post, however I don't have much time to document it. Our new website has more pictures and information though. Stay tuned for more :banana:
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
