I Striped out my R32 GTR halfcut and these are all the leftover parts that aren't required.
All items available to be picked up from Brisbane Southside but will post small items at buyers expense
Contact details: PM or reply here
Cheers Greg
R32 GTR gearbox, includes front drive shaft $600 Pic
R32 GTR front diff, 4.11 ratio inlcudes everything pictured $250 Pic
R32 GTR cam gears $30 Pic
Tensioner and idler bearing used $60 Pic
R32 GTR floor rubber that goes around shifter $5 Pic
R32 GTR stock castor arms $20 Pic
R32 GTR stock power steering cooler $20 Pic
R32 GTR front shocks (KYB gear climb) and springs, light surface rust $40 Pic
R32 GTR radiator and fan shroud $100 Pic
R32 GTR clutch fan $50 Pic
R32 GTR BOV return pipe that runs behind the intercooler, no cracks $50 Pic
R32 GTR engine mounts $50 Pic
R32 GTR strut brace $60 Pic
R32 GTR stock air box $20 Pic
R32 GTR stock turbos, stock dumps and acuators included $200 Pic
R32 GTR intercooler $100 Pic, Pic, Pic
R32 GTR Clutch and flywheel, unsure on brand it has DK stamped on it, 7.5mm of meat left on the clutch $200 Pic, Pic, Pic
R32 GTR front uprights, includes uprights, hubs, half shafts and lower control arms $200 Pic
R32 GTR front camber arms, unsure on brand $100 Pic
R32 GTR slave cylinder $40 Pic
R32 GTR clutch boost and master cylinder $100 Pic
R32 GTR speedo cable $50 Pic
R32 GTR gearbox mount $10 Pic
R32 GTR steering column includes boss kit $50 Pic
R32 GTR washer bottle $50 Pic
R32 GTR wiper arm $10 Pic
R32 GTR complete Air conditioner setup back to fire wall $300 Pic
R32 GTR indicator stalk $5 Pic
R32 GTR stock gauges $30 Pic
R32 GTR stock boost solonoid $5 Pic
R32 GTR plastic underlining $5 Pic
R32 GTR inner plastic guards, with brake ducts/vents $30 Pic
R32 GTR air conditioner/heater setup behind dash $100 Pic
R32 GTR acclerator, brake and clutch pedal $60 Pic, Pic
R32 GTR radiator overflow bottle, has small chip off it $10 Pic, Pic
R32 GTR dash $100 Pic
R32 GTR front sub frame $80
R32 GTR power steering resviour $20 Pic
R32 GTR random interior parts, PM me what you want with a price Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic, Pic
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/
Hey mate im after the window controls on both sides.
Front left head light by any chance?
Hey, would you happen to have the bonnet latch and vertical support?
Thanks!
The halfcut didn't come with any of those parts
BOV pipe, im 99% on that - would you be happy to post it?
Yeah i will post that out to you
What sort of condition are the turbo's in?
I just pulled the dump pipes off both of them, 1 has minimal shaft play the other is missing the exhaust wheel :P
New Price on Turbos $50 includes stock dumps and acuators
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4240608
R32 GTR stock air box SOLD
R32 GTR stock turbos, stock dumps and actuators included SOLD
R32 GTR intercooler SOLD
R32 GTR front camber arms, unsure on brand SOLD
R32 GTR stock gauges SOLD
R32 GTR inner plastic guards, with brake ducts/vents SOLD
R32 GTR dash SOLD
R32 GTR radiator and fan shroud SOLD pending payment
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4248159
R32 GTR dash SOLD
Pm sent
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4248370
got a grille??
G'day mate
Would you have a pair of front indicators for sale?
Cheers
No, the halfcut didn't come with any exterior panels
hey mate, dont suppose you have the fuel pump cradle + rubber mounts for sale??
No i didn't get that with the halfcut
R32 GTR steering column includes boss kit SOLD
R32 GTR washer bottle SOLD
R32 GTR front diff, 4.11 ratio SOLD pending payment
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4254494
hey man
just wondering if you got:
Handbrake assembly with good stiching and handbrake boot in good nick, and also a good nick gear boot?
PM me if u got these parts man
cheers
https://www.sau.com.au/forums/topic/242946-r32-gtr-parts/#findComment-4255634
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
