Hi all,
Thus far ive been content with 0.7 bar 30% duty, but im cautious about messing with the settings as im still running stock ceramic turbos. The car is a 96 vspec GTR and has all the other major bolt on mods. HKS 100mm intercooler, ARC intake, Nismo front pipe, HKS exhaust. The AVCR setup is currently done very basicly since it lost all its config when I had a battery go flat a while back and attempting to start the car resulted in the thing losing all its settings.
So after reading a ton of posts and documentation on the net today im now pretty confused with where to start. I figured that surely the setup for a GTR with stock turbo's has got to be done to death, but I cant find many actual proven settings out there.
What Im after specifically is the recommended gear judge settings, recommended feedback settings and some indication of what duty cycle settings will produce what kind of boost pressure levels.
If anyone has all their NE points documented for any particular boost level I'd be interested in a look. The only info Ive found so far is all for boost pressure's above 1.2 bar, so useless to me.
Cheers,
Ian
its like any boost controller, you set the target boost you want to run
and set a low low duty. floor it in 3rd gear or take off in 3rd and load the engine up
watch what max boost you hit (make sure its low) and when it hits target boost
then slowly increase duty to make it ramp to the target quicker
increase the duty in small parts. if you see the duty too high
it will ramp to the target boost and fly past it, typivcally resultsing in the controller struggling to maintain pressure
ie: it will bleed past the target. some controllers can detect this and cut out / safety cut so be aware.
so set your boost to whatever you want to run say 0.85 or whatever you think is safe (check before gussessing)
and set the duty low, say 30 or 50 and drive, if it takes ages and ages to make 0.85 or if it never does
increase it a little and repeat. try say 60 or 65. dont test it in low gears, try it in say 3rd
bog the engine down heaps in low RPM and let it spool slowly
dont test and try settings in 1st or 2nd gear
it will be too harsh and will ramp instantly
try say 20kmh in 3rd and floor it, it should be laggy as and prefect for testing duty / boost gain settings
THE hks evc III manual auto setting mode states to take off at 0km.h in 3rd gear
and floor it until redline to test gain and duty settings
Thanks Paul, ive read quite a lot of your posts and your documentation on the FC over the past few weeks. Very informative. So any idea's about gear judge and feedback settings? I presume all these setups are done with learning mode on still too right? Ive seen other threads where people turn learning off so they can set the RPM NE points indivitually.
Another thing Ive just read was that with feedback it needs to be higher in the lower gears (4-3ish) and then go lower per gear till 4th and 5th.
So I think I understand about the duty now. Once I get that correct so that it doesnt overshoot the boost level, I can then play with the start +/- settings for each gear to optimised the rate of boost response for each gear right?
Im still looking... Youtube has too many distractions and not a good enough search engine...
On another note, my TPS readout doent go to 0% when the throttle closed. How do I calibrate the 0 throttle setting on the AVCR? I tried initialise a couple of times but that didnt seem to help.
under setting ETC
somewhere in there is the THR type, its either an up arrow or a down arrow
when you mash the pedal it will show you the % opened. so you just change the item
just download the avcr manual - i think its even on my website paulr33.skylinesaustralia.com
if not, try the VAFC manual, it has the same THR setting and control
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
