Ok so ive done most my homework and these are the guys i want to come out! *they have been on other stag cruises* obviously any others are more than welcom!
Sniffles...I'm off the list cause I only came to the meet point on the last one :)
PM me please, I might be able to make it (for the cruise this time!)
  • Replies 166
I"ll be in on this one. I could help plan a nice route, east side of town, through the hills, towards the lower barossa area. Nothing too twisty, just windy country roads and then maybe a meal at a nice pub. Let me know if you want a hand organising route, notes etc.
Hey Adam,
I just remembered I have that I have a mate with a silver S2 RS260 that might be keen. He came on the last one, Josh. I will ask him and tell him to come along as well as sign up on SAU.
I hope I can find some intercooler piping and another front bar before this cruise...
most people should have there pm by now! ill b going threw and sending them to ppl who havnt piped up yet... ruby if you could atleast start making a map or sumthing that would be great... i think the usual small windey section, town/bay run chat etc etc is good for us stagea driver... take it easy!
Can I have your home email Adam? I've got a nice route in mind ... I wanna email it to see what you think. It'll cater for all tastes :P
ill try make it to this 1 no promises tho...
pm me meet point and route. :D
p.s. its markrx3 here.. aka the old STAGEAAAA.
Mark as in Mark that I saw at the Vic when I was there with my manual Stagea? If so, it's Peter. I used to work down at Lonsdale not in plumbing, but in irrigation. If it is who I think it is, you will know what I mean by that, hahaha.
Anyway, the more Stageas the better!!!!!!!!!!
Well unfortunately I cant make it on the 23rd will be in Tasmania for a wedding. Looking forward 2 a cruise now that I have a new turbo for the Stag :D.
You dont want to make it for the following weekend ?.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
