if you guys are interested in getting some photo work done, i would love to come along, only have 2 issues..........
1) i drive a yaris so i don't think you guys want that on the cruise, even tho it is a cool yaris ;)
2) I think i only know one person on here.... Kidafa
would have finished my exams by then and also my 10-20mm lens would have come in by then...
  • Replies 166
Mark as in Mark that I saw at the Vic when I was there with my manual Stagea? If so, it's Peter. I used to work down at Lonsdale not in plumbing, but in irrigation. If it is who I think it is, you will know what I mean by that, hahaha.
Anyway, the more Stageas the better!!!!!!!!!!
yea thats me lol....
might see you all on the cruise. pending if i can get tint, zorst and detail done by then
ill pm you.... i HAVNT heard from the following people...
rsfour
rsfour1
daysrs4
stagstock
mr500
jav360
bensdr30
shadowknyte
32godzilla
snoozer
dazza88
piratewake
kombi86
dmonic
ryhs5164
ill pm them shortly... cheers
Edited by chef_stagea
who wants to wash my stag before the big day??!
looking forward to it, hope there are some good driving legs; want to give the girl a run.
been hitting up the twisties a bit at night, going really nicely. good power and handling ability
So how is the planning of this one going Adam?
Really looking forward to it! :P
yeha good man. spoke to ruby last night and looks like its going to be the biggest 1 yet! :D if any one spots a stag tell them!
incase any one missed the meet point pm me again. but WE ARE NOT meeting at newton like i think some people think we are. if your confused pm me. :D
:P Um.. i dont think we're gonna be able to make the cruise next sunday... the stag is currently sitting on 98,700km and we can't service it until next month so gotta make those km's last! NOO!! Stupid car :D So dissappointed... GODDAMMIT!!!
Sez
Sez
for real? 100k service doesn't have to be done bang on 100thou.. just come.. without excuses :D
;) Um.. i dont think we're gonna be able to make the cruise next sunday... the stag is currently sitting on 98,700km and we can't service it until next month so gotta make those km's last! NOO!! Stupid car :( So dissappointed... GODDAMMIT!!!
Sez
our RS4 got serviced 13000ks after the 100000ks mark and she's fine! :D
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
