I'll be in for next week.
PS. I for-filled my dream today....no I didn't get to Lay Angela Jolie.......but I did get to drive the 1992 Bathurst winning Winfield R32 GTR at pace at the Oran Park......mmmmmm.....still buzzing....and to think I have two more days of driving it
PSS. And yes I am gloating :D
Edited by Jetwreck
  • Replies 402
Posted Images
PSS. And yes I am gloating :)
Stop that glotting you bastard. :D
PSS. And yes I am gloating :spank:
You lucky MoFo, Craig!
I get to look at it every day, it's just a shame it's only in 1:18 scale... :down:
Sorry guys won't be able to make it this Thursday, it's my wife's birthday.
so bring her and we will take a cake :)
Yeh exactly, we always have carpark cake up teh coast for birthdays!
OK peoples, I'll be cruising up this week as per normal, but I have another quick message for you all:
If you're not already an SAU-NSW club member, sign up quick-smart and send me a PM as soon as you do, as we have our yearly SAU-NSW Christmas Cruise on this weekend!!!
Sign up for membership HERE!
Hey Nick, Its Brian
Might remember me from the SAU Show n Shine at Granville, Was with dad and his R31 wagon?
Also, from the Richmond Stag cruise couple o' years back! And bumping into you at Autosalon... (last year?*)
I have ended up buying a R31 Ti so therefore resigned up with a new username.. And my father is still yet to 'update' and purchase a Stag! im extremelly dissapointed!
I would come on the Chrissie Cruise if I had known of it earlier and put in for time off work!
Might have to join you guys one thursday Night for this cruise! I went up Old Pac last Saturday on a Suzuki Cappuccino cruise... Had no chance keeping up with those things around corners... Will be buying one soon, Should be fun.
Edited by BriansTi
no cruise for me tonight fellas... have to spend some quality time with the missus... just got back from brisbane
was a good cruise last thursday tho... good to meet some other stagea owners
Edited by Space Goat
I'll be there as per usual.
And hey Brian, yep I remember you. I should be at AutoSalon on Sunday at the SAU stand, so I might catch you then if you're heading in. Good work snapping up an R31, and hope to catch you on a Thursday night cruise soon!
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
