  • Replies 402
Posted Images
There is still a chance I may make it tonight.
I'm back on the coast and it doesn't look like I have to drive back tonight.
So I may catch up with you guys at Fountain Plaza.
wanted to come but I have a little problem with the exhaust side of my turbo.....it's not attached to the turbo anymore.....low compression V6 2.5lt motor pushing close to 2T isn't fun.
That's not much good Jetwreck, hope you get it sorted soon.
Looks like change of plans for me, I don't think I will be able to make it tonight.
Hopefully make it next week or the week after, see how my fuel bills go :sweat:
yup me not coming either tonight, mrs was made redundant and we looked at a new car for her tonight - Fiat 500
yes, no job, and new car. dont ask. but ill bring it one week instead of the stag :sweat:
.... one of these days we will both make it!
I don't feel so bad I missed it now, I was looking forward go getting a look at another m35 inside and out lolz
We'll have to get our act together soon tho.
she can drive?? god help us all!!
please dont tell her i said that :D
did you forget to take your medication? :)
First you pick on my car and now you are picking on Rosie, sheesh!! Rosie will sort you out if you don't watch it :(
Greetings.
I've got an appointment on the coast tomorrow afternoon, so I will hang around and meet you guys at Fountain Plaza :D
Hope to see some Stag's there!!
I should be there, as long as it isn't absolutely BUCKETING down. Light to medium rain is fine, it just means we head off for a feed a bit earlier, which is fine by me...
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
