Guest MRE
Took a R33 GTSt for a spin the other day.
Had a massive pod set up.
Was so loud that after 3,500 rpm people on the street started turning around like I was pumping some fat base tune [img:d0aa96c78f]http://www.west-lan.net/forums/images/smiles/lol.gif[/img:d0aa96c78f]
Was quite funny.
I like the wooshing sound but this one was a bit to much
https://www.sau.com.au/forums/topic/243-whistle-from-skylines/#findComment-9401
Guest dieline
I agree, very intoxicating ...
When I put my RB20DET in my Navara it did ... and still does turn heads with that gourgess sound ...
On another note, thought some will find this amusing, when I got pulled up in it one night (brake lights were out) and asked to pop the bonnet, all the cop said was air filter, loose battery and thats it! Didn't notice the large NISSAN 24v TWIN CAM badge smack bang in the middle of the cam cover, nor the ceramic turbo decal, nor the fact it was missing a radiator support pannel (its back in now) and had two thermos where the grill is meant to be ...
Heh heh heh.
https://www.sau.com.au/forums/topic/243-whistle-from-skylines/#findComment-9409
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
