got pretty bored so i got rid of the neo engine cover
looked ok, but still bored. coilpack cover was dirty so took that off and gave it a clean.
still bored. found a can of black spray paint in teh garage so i gave it a respray.
looked much cleaner (excuse the shit phone quality pics) , although i was still bored...
was looking through a box full of junk, found a black metal "skyline" badge.
a bit of paint stripper + polish later the badge came up lookin nice and shiney.
hmmm what to do now? put 2 and 2 together, took the badge and mounted it on the coilpack cover
anyone wanna guess what i got this badge off? :):D
post-31699-1225636002_thumb.jpg post-31699-1225636019_thumb.jpg post-31699-1225636043_thumb.jpg
just thought i'd share
thanks
Edited by R-SPEC
https://www.sau.com.au/forums/topic/243013-got-bored-yesterday/
anyone wanna guess what i got this badge off? :(:D
thanks
I rkn you got the badge off the floor mats, am i right?
Hey R-SPEC!
What polish did you use?
I really don't know what to buy and auto barn sold me mag and alloy wheel polish and is only good on bare metal not paint metal.
i think it was actually some oven cleaner. cant remember exactly :huh:
correct :P
how long did it took you to take the pipe off???
a couple minutes
paint = paint wax/polish same as outside the car
polish alloy - metal polish - autosol/meguirs metal polish/etc
as for making old alloy cover into polished - look at the polishing thread in the fabrication section.
Yeah cool, I got Auto Glym car polish, I give that a go on my rocker / cam covers
I got Mothers alloy/mag polish but only works on bare metal stuff as you know.
Thanks man!
Thanks man!
if your covers are std r32 GTR black - no polish will make them look nice - the stuff is matt finish and not smooth.
So can you suggest anything else or would I have to take the covers off, sand them down and repaint them?
that silicon spray stuff might work for you to make them look fresher ( its like using armorall) but can attract and allow dust to stick to it.
up to you and what you want to achieve with the covers, above is cheapest by all means.
Yeah a friend told me about that silicon spray / armorall stuff too and thats pretty much what Iam after but auto barn sold me Mother Mag / Alloy polish and it can not be used on painted surfices.
Just a more fresher look.
Here is an example of what Iam after.
This pic is from the Zele International website from Japan and I think they spend a lot of time in cleaning their engine bays.
R32 GTR
R33 GTR
As you can see it looks fresh as!
thats been resprayed with a glossier black than the standard paint... if you want it done properly track down some spare covers and timing cover and get them done in a spray booth with proper automotive paint... it bakes on so there will be no flaking and wont chip and scratch as easily, has a much nicer finish and can be polished just like your car.
im spray can guy myself, ive never had any problems, and usually results in a good enough job for the amount of time people see under the bonnet... a)because im cheap, b) because i get bored and like to change colours and c)im cheap
Yeah right, thanks!
I probley see what I can find at any import wrecker place for the cam and timing covers.
Cool and thanks again! :P
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
