Hey i compression locked today coming up to a set of lights and it made my car go abit sideways on approach. When i stopped for the red light i looked over at the servo on the other side of the road and there was a cop car, 2 police got outta the car and were looking my way. Could they have fined me for anything?? Like i was doing a skid and it wasnt intentional, i just left it abit late to be stopping. Undue noise fine or something along those lines?
https://www.sau.com.au/forums/topic/24302-compression-lock/
Dec last year I took off from sum lights and had sum wheel spin through 1st and then chirp into 2nd and kept going.. got pulled over and fined for “not having full control of the vehicle”.. so I take it to court and the cop changed it to “careless driving”.. the law is if your tires don’t have 100% traction you can be fined for “not having full control of a vehicle” or “careless driving”
https://www.sau.com.au/forums/topic/24302-compression-lock/#findComment-519175
the only way they can get you is if they can prove that it was intentional! but you may have to fight it in court, but easy out was to stop for orange/red signal as going through them is also an offence!!!
but you have to fight it, a mate of mine got done for doing a burnout is his brothers sprinter!! the fine said that it was spinning the front wheels, pretty funny seeing it is a rear wheel drive car!!! thats what having p plates on your car does to coppers :(
https://www.sau.com.au/forums/topic/24302-compression-lock/#findComment-519575
If the loss of traction is for 5 seconds or more, its a burnout (negligent driving, sustained loss of traction). Anything less is negligent driving, and they will do you for it. A friend lost traction for 2 seconds, and the cops jumped straight on him for negligent driving, loss of traction.
If they didnt book you on the spot though, I dont think much will happen, and then you could possibly argue you had to in order to stop in time (assuming it was an orange light or something?).
https://www.sau.com.au/forums/topic/24302-compression-lock/#findComment-519648
May I ask why you compression locked the car aproaching a set of lights? What did u do throw it back to first on approach? Or do you mean that u locked the brakes apon aproach?
Just curious.
Warpspeed,
Oh dont worry it is illegal put other in danger for the sake of a dog. That won't save u.
Mick.
https://www.sau.com.au/forums/topic/24302-compression-lock/#findComment-520111
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
