Hi guys iv been a skyline lover all my life and now i can finaly afford one everone is saying im not going to be able to get insurence because im 17 and will have only had my license for about 3months when im about ready to buy the car. Is there anyone out there that will insure p-plates iv called famous and they pretty much intruped me with no asoon as i said skyline they said that they wont insure unless ur 20 and have a clean driving record
https://www.sau.com.au/forums/topic/243094-insurence-for-r33-gtst-and-p-plates/
Yeah justcar but u dont wanna know the premium for full comp. I got my r33 when i was 17 too and the premium was like almost 4000.
so i went with 3rd party without fire and theft; keep a safe distance from the car infront, pay attention while driving and dont be an idiod in the rain.
well my dads giving me his ford falcon as sooon as i have my lisence so thats the first coz i dont realy wana spend anymoney on other shit cars id rather keep saving for a nice skyline the longer i wait the nicer it gets
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
