  ZXY said:
for a turbo car i reckon you cant go wrong with a electronic boost controller or a aftermarket ecu. An aftermarket ecu will open doors for any future modifications and will give you the best out of them.
I plan to do more in the future. Basically a semi project car, so everything I buy needs to be compatible with future upgrades etc.
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4237778
If you don't plan on upgrading turbos any time soon, take a look at this topic: (1/4 times for GTRs running stock turbos)
http://www.skylinesaustralia.com/forums/Gt...ck+gtr+times+12
Plus there are a trillion topics on SAU about how to spend your money on a GTR.. but based on the above topic it seems that all you need is a good clutch, boost controller, zorst (which you have) and bingo you've got low 12s 1/4. As for power, see that topic as well.
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4238062
Can't go wrong with the:
Apexi PowerFC D Jetro ~$1800 now with the poor yen + ~500 tune and install.
Greddy PROFEC B ~$550 now with poor yen then ~150 to install, takes very little time.
Button Ceramic Clutch ~700-1200 ~$300-500 install
Keep it under a bar of boost will keep it safe with the ceramic rear's if it is not a VSPEC and expect 300-350hp~ safe with 12.5's~ @ 107-111mph~ which is a awesome street car. If you interested in running alittle quicker other upgrades like turbo's, injectors, fuel pump, manifolds, dumps, cams ect will be needed. You obviously can take shortcuts and push the stock turbo's harder and slap a aggressive tune but it will cost you more in the long run.
Hope that helps.
Edited by monga
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4238372
Hope that helps.
Exactly what I was after :). 300-350 hp is around what I want, it seems to be about the plateau area after that price starts to increase dramatically against performance gains.
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4238476
That's it, I'd be leaning more towards 330-350HP also as generally you would expect around 250-280HP from a bog stocker, but you have to consider the age of the motors now so not many will be running in show room condition. Also HP is a strange thing so don't be to concerned, MPH is a better indicator of how things are heading.
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4238608
definatly agree with what monga has said, however i personally would be inclinded to change to some turbos with steel wheels, if only for reliablity , ceramic dust sucks :P . perhaps chase down some second hand hi flows, or even get some new 2860s if budget can stretch, but then there is injectors/afms and on and on.
Edited by Jolinator
https://www.sau.com.au/forums/topic/243095-modding-r33-gtr/#findComment-4240632
