Hay all.....
Anyone got a MY00 WRX or know of someone
that has one and is after some Coils???
Item: ISC Coilovers
Age: 6 months
Condition: Excellent
Features:
32 Step Damper Adjustable
-Precise control damp valve
-Operates smoothly on all road surfaces
-Expansion/Suppression of shock adjustment
Pillowball Uppermount
-Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
-High rigidity steel piston rods
-Meets with race/sport standards
Sports Spring
-Made from high quality SAE9254 steel
-Tested over 500,000 times on compression inspection with less than 5% deformation.
Ride Height Adjustable
-Full length height adjustable
-Bound adjustable with separate spring locks
-High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
-Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
-Specifically anodised surface to prevent inside corrosion and surface rust
-On various models camber can also be adjusted via the bracket aswell as the camber tops
Single Cylinder Design
-Larger cylinder and piston design to advance driving stability and dexterity
Price: $900
Pm or call me on 0412664221
Cheers
Luke.
https://www.sau.com.au/forums/topic/243097-fs-my00-rexy-coilovers/
