sorry to hi jack, recently installed a rb20 actuator and now its overboosting to about 16+psi !. I've been reading and believe i hooked up everything correctly. I'm puzzled now :S. Current mods, 3'' bellmouth and zorst, turbotech boost T set to ~12psi and a nistune remap.
Prior to this problem I had another 1, my boost would drop from 12psi to about 10psi only in high revs (5500-redline), the actuator was suspected so i replaced with rb20 1 and now this :)
Any ideas guys?, only thing i changed during isntalltion was extending the vac line from actuator to boost T to cooler pipe to reach. :S
I take it you have ditched the stock solenoid? Tried adjusting the boost T (without regard to any markings on it i.e. adjust the boost downwards)?
  • Replies 42
I havn't adjusted the boost T yet. I just put the rb25 actuator back on and its back to square 1.
My next question is, does this mean the rb20 actuator is faulty? OR could it mean that i need to re adjust my boost T?
I only didn't want to touch the boost T was cos its tuned for the ecu already and i dint wana change the settings being a manual BC its very annoying to adjust to the boost you want. hmmmm
