  • Replies 47
Well despite the lack of people (there were only 4 of us) a good time was had. In regards to time Andrew and I were quite slow today but Guy and Ben were quick (Guy has the official times).
Edit: Forgot to mention....Top stuff from Ben donating for the first time.
Edited by Eddyfier
Yeah, our blood donation lap times were as follows;
Guy 5:46
Me 5:47
Eddy 9:00
Andrew 9:xx ?
I was very bummed that Guy pipped me, I was almost certain I'd have won first. Next time I'm going to smoke and drink and eat kfc for a good 2 weeks beforehand so my blood pressure goes thru the roof, I reckon then i'll have a 5:00 flat.
Oh yeah and Guy cheated cos he had a squeeze ball and I didnt. Nyaaah.
And Steve can come next time with chequered flag, marshalls hat and a notepad to record the official times. I think thats more of an incentive. I'll buy the winner a villies pie (so I hope I win).
-D
good to read that someone new went (thanks ben :)). sorry i wasnt there, woke up and felt like death, couldnt make myself get up.
Edited by scandyflick
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
