hi guys, i have an ECR33 s1 and its time for my maintenance(some pulleys giving me weird noise and for the love of my car, i just want to be safe and run a full belt/items change on it, its about time too anyways). Ran a search on the forum and i found these part numbers. Just want to be sure before i place my order at a local garage, can someone clarify if these are correct?(all standard nissan items)
Timing belt:13028-20P25- for rb25det non neo head
Belt Fan & Alternator: AY140-40850-
Belt Compressor: AY140-40910-
Belt Power Steering and Oil Pump: AY140-30845-
missing part numbers:(need info)
Idler pulley:???????????
Tensioner Pulley:???????????
Nissan Crank Oil Seal:13510-50B10 (Not sure what is this part for, but i might just want to change it. The part number is for ER34, anyone know if it will fit my ECR33?)
Should i miss out any items that need to be replaced please do let me know! Your knowledge is my powah lol.. Thank you in advance guys!!!!
https://www.sau.com.au/forums/topic/243122-100k-service-parts-number/
there was a thread a while back with numbers i and others posted up for parts. i dont know where i put my reciept for all my parts from nissan. will have a look for it and yeah do your water pump while your at it for piece of mind. check your exhaust manifold studs too if theyre broken.
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
