Looking at available specs, and the instructions on my ACL Race Series MLS gasket I have come across something that's worth asking you engine builders about.
Stock RB25 specs require a tightening sequence, with final tension of 93-103Nm
Stock RB30 specs require similar sequence, with final tension of 88Nm
ACL spec sheet still follows the same sequence, and final tension as per the stock RB30. Difference is that the gasket is listed for fitment with 30ET 2 valve head.
I'm leaning towards a final tension of 95-100Nm on the basis that the needs of the 4 valve head are different and requires the extra. Will call the ACL tech help line, but meantime what are the settings commonly used by those of you who've built your own 30DET?
https://www.sau.com.au/forums/topic/243131-head-bolt-tension/
I wasn't aware of the difference in length, but would nearly think that a longer bolt would require more tension due to extra flex/torsion in the shank.
Either way, the higher torque value for the 4 valve head application looks to be the go for me.
Any opposing views or experiences?
Im assuming your using used rb25 bolts. I would go the higher value with a 10% extra on top (say around 113-115nm). I think the extra should allow for the stretch and flex in the used bolts and since its not a bearing, having abit more wont really hurt. I went the extra in my road rb25 when i rebuilt it, not a rb30 block, but same head and bolts and a threaded hole is a threaded hole. The only thing you might think about is that you are probably running a higher static comp to what the std sohc rb30s ran...so naturally you now will have more force trying to lift the head and that will only grow depending on how much boost your going to run from whichever turbo your system utilises.
New head bolts - Nissan genuine.
Static comp running cast pistons ~ 8.35:1, so lower than the 9.0:1 advertised for 30E with the 2 valve head. But running in boosted configuration, I felt the higher tension than 30ET would be better. Perhaps a touch higher still at 105-110Nm is not a bad idea for a reliable seal.
I'll find out what the ACL tech advice is today.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
