I had a bet with a mate.. and he believes theres a power difference if theres a single exhaust..
We're talking about the tip of the muffler..
Quoted by someone on the forum.. -->
Because twin or single its going to make absolutely no diffrence. Its far too late in the exhaust system for it to have any effect of noise or "performance" or anything of the sorts.
please share your opnion..
Does it really make a difference if the exhaust tip is single or twin?
could have just asked the question in here.... http://www.skylinesaustralia.com/forums/Tw...le-t242824.html
(where you got that quote from)
anyway... its n/a power I am assuming you are talking about? not going to be a single difference... maybe max 1kw/2kw depending on overall setup, but if you have a good system (manifold to back of car) it doesnt matter what the tip is going to be...
but for argument sake lets look at the math of it....
if you have twin exhausts, each coming out to 2 2.5inch tips = 2*2.5 = 5 inchs of good 'ol super cheap auto chromey tip
or if you want a cannon that has a single big 5 inch tip = 1*5 = 5 inchs of good 'ol super cheap auto chomey tip
see what I mean... its not really going to make any difference.... get a 500kw dyno monster that needs all the flow it can get and then yes... different setups will impact on the cars performance.
Adam
What Adam said covers the answer.
On another note though, the oval twin tip mufflers are apparently known to drone quite a bit on N/A Skylines, as I've been told by one of the guys at Rob Bliss Exhaust in Brisbane. That was the advice I was given when I was asking about a twin tip set up, simply for a factory looking system.
I don't like to be the one to say it, but if you do a search through these N/A forums you'll find that N/A Skyline Exhaust systems have been pretty much done inside out...
Adam
ROFL...
2x 2.5" pipes IS NOT the same as a 5" pipe.
5" == 12.7cm == cross sectional size of 126.67cm^2
2.5" == 6.35cm == cross section size of 31.67cm^2 x 2 == 63.34cm^2
thus, 4x 2.5" pipe is equivilent to a 5" pipe.
the tip size will only make a difference if the original is too restrictive
the biggest exit AFTER teh muffler the better
too big and droney and noisy as fuck - something like a 3" single exit or a twin 2.5" depending on taste would sound alright
the biggest restriction in teh whole exhaust should be the muffler - theres a reason for that - its called legalities regarding noise lol
the ultimate would be straight pipes - but thats noisey as fuck
Edited by 342Four
Gosh who ever you quoted that from is an AWESOME bloke!
You have your answere in your first thread.
Twin or not. There is no difference. I dont care. There just isn't.
Its too late in the exhaust system. The gass is being pushed out, the tips are ALWAYS bigger than the rest of the system etc. etc. etc.
its only for the look.
Do I need another "In Before the Lock" photo too?
Is it school holidays already?
Edited by GTS4WD
haha... well said Chris.... :(
and Mitchy.... I am glad you found my post that amusing that you rolled on the floor laughing outloud while reading it... please put a youtube vid up to show you did it or dont comment saying that crap.
god knows where you pulled the cross sectional values anyway..you went from 12.7cm to 126.67cm how?
regardless, if you really believe a twin TIP (NOT the whole system) is going to make that much difference please show me comparission dyno threads. but from what my mates and I have tested... a single big TIP or two tips each half the size of the big one is not going to make the slightest difference for a road car.
and because Chris seems to be the guy to quote off it seems appropraite that I repeat his words so that you may understand.
"Twin or not. There is no difference. I dont care. There just isn't.
Its too late in the exhaust system. The gass is being pushed out, the tips are ALWAYS bigger than the rest of the system etc. etc. etc."
^^^^dude its called math
5" is 12.7cm
area of a circle equals Pi*R(sqaured)
radius is half of 12.7cm = 6.35cm
that squared = 40.3225 square cm
times THAT bi Pi and you get 126.7 square centimeters cross sectional area of a 5" tip
to get the equivalent area from a 2.5" tip you need 4 2.5" tips (cross sectional area of a 2.5" tip is 31.7 square centimeters)
a tip CAN be too restrictive
imagine a 2" tip on a 3" exhaust
its like trying to blow up a balloon with a straw - ur going to get tired, and the balloon is not going to get very full
There is a big difference between them....Police see a cannon and get interested in your car very quickly :) A factory looking twin system doesn't get any real attention in comparison :P
Yes.. this is true. But even the supercheap items have the tip welded to the muffler so its impossible to mess this one up.
All mufflers have a tip larger than the entry point.
Im not arguing with you the math of a FULL system, I know theres a big difference... but as if you have a 3inch system with a 2inch tip... unless you welded it together yourself you couldnt buy it like that.
I suppose you could weld the tip of the miffler to the exhaust and leave the inlet as the tip. :down:
So as the muffler is 3inch to a 2 inch tip. or something of the sorts. :laugh:
Back to the thread,
IBTL
adam, what mitch said about calculating the area of the exhaust (i.e. cross section) is 100% correct.
some of you guys are going around in circles. firstly you need to understand what the muffler is for.
the muffler is basically a point where the flow of exhaust gases are muffled by distrupting the airflow. the gases are passed through a series of perforated pipes in various baffled chambers. they are then expelled outside and voila! quiet exhaust. i suggest some of you go and open a muffler up if you get the chance and understand how the internals work.
too big and droney and noisy as f**k - something like a 3" single exit or a twin 2.5" depending on taste would sound alright
the ultimate would be straight pipes - but thats noisey as f**k
i would say 99% correct ashley! good work. the other 1% i will explain a little later.
the other 1%. even if the end pipe of the muffler (i.e. tip) is the biggest, which will help to some degree. it also comes down to the design and sizing of the internal pipes, perforations and camber sizes.
so the million dollar comment is: you can not just look at the tips alone. it ultimately comes down to the research and development behind the product it's internals and how well the muffler as one entire package is able to maintain good flow properties and keep the exhaust volume under legal limits.
and yes ash, straight pipes would be the sweet sweet ultimate.
edit: see pics for a better understanding
a straight through muffler is exactly as it suggests
a good quality straight through muffler you should be able to look right through it from exit to entry (unless of course you have an offset exit/entry)
the muffling on a straight through is done by a baffle chamber AROUND the exhaust - perforations or the like in the pipe in the muffler allow flow to diffuse into the chamber and muffle the sound
thats essentially how a cannon works
the muffler in the last pic by eug is a typical factory exhaust muffler - sound is very quiet, but very very restrictive - the exhaust gases have to change direction 3 times and in a small body this is going to choke the gases BIG time and slow everything down and not flow well at all
lol here is a crappy photoshop pic
the bottom one is a common aftermarket muffler - exhaust comes in from right - goes out main pipe and diffuses into exit pipe
they usually flow alright and arent too restrictive
the top one is an straight thru highflow item - gases diffuse into baffle chamber around the pipe
generally the bigger the baffle chamber the quiter it is, but also can very droney as the gases start to 'echo' a lot more
Thanks for the lesson! definetly understood much better now!
Thanks mitch for trying to explain it... I just didnt understand how you went from 12.7cm to 127.xxx ... but as soon as someone said pieR^2 I got it.
Least I learnt something today!
regards,
Adam
P.S isnt it funny how "awsome" hasent even replied to his own thread?!
do circular twin tip mufflers even exist? if so thats what id want to get if the drone is the case.
(saying that my exhaust drones alot and its round)
regards,
Adam
Which thread? He has too many to keep track of lol
i'm suprised to see this thread is still going, but with that said though, it's been quite an informative lesson on mufflers which is good to see!
WOW..
way to complicate things boys! :huh:
Yes. This is true what is being said. Theoretically.
But in all honesty.
Take a step back!
This is not a defining aspect. There are far more important issues (Air temp, humudity, dyno, petrol, air flow, air quality etc.) that will be more influential in a "final figure" in terms a power figure or even the "seat of the pants" test. Your going doing to experience any diffrence. These very minor details are not going to have huge effects upon a vehicles performance (well not when your talking about ye ol faithful RB25). When you get to the world stage of V8's, touring cars F1 etc. these insignificant diffrences make a diffrence. But even then you dont have to worrie about mufflers.
So I suppose its just a thread for a thread's sake, an argument for the sake of arguing.
I suppose its an interesting thread as an idea. But little practicallity.
Simple is always best.
And simplest is straight. Either way its going (twin or single) to make bugger all diff.
And final word is:
:P
Edited by GTS4WD
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
