I had a bet with a mate.. and he believes theres a power difference if theres a single exhaust..
We're talking about the tip of the muffler..
Quoted by someone on the forum.. -->
Because twin or single its going to make absolutely no diffrence. Its far too late in the exhaust system for it to have any effect of noise or "performance" or anything of the sorts.
please share your opnion..
Does it really make a difference if the exhaust tip is single or twin?
could have just asked the question in here.... http://www.skylinesaustralia.com/forums/Tw...le-t242824.html
(where you got that quote from)
anyway... its n/a power I am assuming you are talking about? not going to be a single difference... maybe max 1kw/2kw depending on overall setup, but if you have a good system (manifold to back of car) it doesnt matter what the tip is going to be...
but for argument sake lets look at the math of it....
if you have twin exhausts, each coming out to 2 2.5inch tips = 2*2.5 = 5 inchs of good 'ol super cheap auto chromey tip
or if you want a cannon that has a single big 5 inch tip = 1*5 = 5 inchs of good 'ol super cheap auto chomey tip
see what I mean... its not really going to make any difference.... get a 500kw dyno monster that needs all the flow it can get and then yes... different setups will impact on the cars performance.
Adam
What Adam said covers the answer.
On another note though, the oval twin tip mufflers are apparently known to drone quite a bit on N/A Skylines, as I've been told by one of the guys at Rob Bliss Exhaust in Brisbane. That was the advice I was given when I was asking about a twin tip set up, simply for a factory looking system.
I don't like to be the one to say it, but if you do a search through these N/A forums you'll find that N/A Skyline Exhaust systems have been pretty much done inside out...
Adam
ROFL...
2x 2.5" pipes IS NOT the same as a 5" pipe.
5" == 12.7cm == cross sectional size of 126.67cm^2
2.5" == 6.35cm == cross section size of 31.67cm^2 x 2 == 63.34cm^2
thus, 4x 2.5" pipe is equivilent to a 5" pipe.
the tip size will only make a difference if the original is too restrictive
the biggest exit AFTER teh muffler the better
too big and droney and noisy as fuck - something like a 3" single exit or a twin 2.5" depending on taste would sound alright
the biggest restriction in teh whole exhaust should be the muffler - theres a reason for that - its called legalities regarding noise lol
the ultimate would be straight pipes - but thats noisey as fuck
Edited by 342Four
Gosh who ever you quoted that from is an AWESOME bloke!
You have your answere in your first thread.
Twin or not. There is no difference. I dont care. There just isn't.
Its too late in the exhaust system. The gass is being pushed out, the tips are ALWAYS bigger than the rest of the system etc. etc. etc.
its only for the look.
Do I need another "In Before the Lock" photo too?
Is it school holidays already?
Edited by GTS4WD
haha... well said Chris.... :(
and Mitchy.... I am glad you found my post that amusing that you rolled on the floor laughing outloud while reading it... please put a youtube vid up to show you did it or dont comment saying that crap.
god knows where you pulled the cross sectional values anyway..you went from 12.7cm to 126.67cm how?
regardless, if you really believe a twin TIP (NOT the whole system) is going to make that much difference please show me comparission dyno threads. but from what my mates and I have tested... a single big TIP or two tips each half the size of the big one is not going to make the slightest difference for a road car.
and because Chris seems to be the guy to quote off it seems appropraite that I repeat his words so that you may understand.
"Twin or not. There is no difference. I dont care. There just isn't.
Its too late in the exhaust system. The gass is being pushed out, the tips are ALWAYS bigger than the rest of the system etc. etc. etc."
^^^^dude its called math
5" is 12.7cm
area of a circle equals Pi*R(sqaured)
radius is half of 12.7cm = 6.35cm
that squared = 40.3225 square cm
times THAT bi Pi and you get 126.7 square centimeters cross sectional area of a 5" tip
to get the equivalent area from a 2.5" tip you need 4 2.5" tips (cross sectional area of a 2.5" tip is 31.7 square centimeters)
a tip CAN be too restrictive
imagine a 2" tip on a 3" exhaust
its like trying to blow up a balloon with a straw - ur going to get tired, and the balloon is not going to get very full
There is a big difference between them....Police see a cannon and get interested in your car very quickly :) A factory looking twin system doesn't get any real attention in comparison :P
Yes.. this is true. But even the supercheap items have the tip welded to the muffler so its impossible to mess this one up.
All mufflers have a tip larger than the entry point.
Im not arguing with you the math of a FULL system, I know theres a big difference... but as if you have a 3inch system with a 2inch tip... unless you welded it together yourself you couldnt buy it like that.
I suppose you could weld the tip of the miffler to the exhaust and leave the inlet as the tip. :down:
So as the muffler is 3inch to a 2 inch tip. or something of the sorts. :laugh:
Back to the thread,
IBTL
adam, what mitch said about calculating the area of the exhaust (i.e. cross section) is 100% correct.
some of you guys are going around in circles. firstly you need to understand what the muffler is for.
the muffler is basically a point where the flow of exhaust gases are muffled by distrupting the airflow. the gases are passed through a series of perforated pipes in various baffled chambers. they are then expelled outside and voila! quiet exhaust. i suggest some of you go and open a muffler up if you get the chance and understand how the internals work.
too big and droney and noisy as f**k - something like a 3" single exit or a twin 2.5" depending on taste would sound alright
the ultimate would be straight pipes - but thats noisey as f**k
i would say 99% correct ashley! good work. the other 1% i will explain a little later.
the other 1%. even if the end pipe of the muffler (i.e. tip) is the biggest, which will help to some degree. it also comes down to the design and sizing of the internal pipes, perforations and camber sizes.
so the million dollar comment is: you can not just look at the tips alone. it ultimately comes down to the research and development behind the product it's internals and how well the muffler as one entire package is able to maintain good flow properties and keep the exhaust volume under legal limits.
and yes ash, straight pipes would be the sweet sweet ultimate.
edit: see pics for a better understanding
a straight through muffler is exactly as it suggests
a good quality straight through muffler you should be able to look right through it from exit to entry (unless of course you have an offset exit/entry)
the muffling on a straight through is done by a baffle chamber AROUND the exhaust - perforations or the like in the pipe in the muffler allow flow to diffuse into the chamber and muffle the sound
thats essentially how a cannon works
the muffler in the last pic by eug is a typical factory exhaust muffler - sound is very quiet, but very very restrictive - the exhaust gases have to change direction 3 times and in a small body this is going to choke the gases BIG time and slow everything down and not flow well at all
lol here is a crappy photoshop pic
the bottom one is a common aftermarket muffler - exhaust comes in from right - goes out main pipe and diffuses into exit pipe
they usually flow alright and arent too restrictive
the top one is an straight thru highflow item - gases diffuse into baffle chamber around the pipe
generally the bigger the baffle chamber the quiter it is, but also can very droney as the gases start to 'echo' a lot more
Thanks for the lesson! definetly understood much better now!
Thanks mitch for trying to explain it... I just didnt understand how you went from 12.7cm to 127.xxx ... but as soon as someone said pieR^2 I got it.
Least I learnt something today!
regards,
Adam
P.S isnt it funny how "awsome" hasent even replied to his own thread?!
do circular twin tip mufflers even exist? if so thats what id want to get if the drone is the case.
(saying that my exhaust drones alot and its round)
regards,
Adam
Which thread? He has too many to keep track of lol
i'm suprised to see this thread is still going, but with that said though, it's been quite an informative lesson on mufflers which is good to see!
WOW..
way to complicate things boys! :huh:
Yes. This is true what is being said. Theoretically.
But in all honesty.
Take a step back!
This is not a defining aspect. There are far more important issues (Air temp, humudity, dyno, petrol, air flow, air quality etc.) that will be more influential in a "final figure" in terms a power figure or even the "seat of the pants" test. Your going doing to experience any diffrence. These very minor details are not going to have huge effects upon a vehicles performance (well not when your talking about ye ol faithful RB25). When you get to the world stage of V8's, touring cars F1 etc. these insignificant diffrences make a diffrence. But even then you dont have to worrie about mufflers.
So I suppose its just a thread for a thread's sake, an argument for the sake of arguing.
I suppose its an interesting thread as an idea. But little practicallity.
Simple is always best.
And simplest is straight. Either way its going (twin or single) to make bugger all diff.
And final word is:
:P
Edited by GTS4WD
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
