looking around 3 - 4 K for the Halfcut with running gear labour depends can do most urself and just get the wiring done
Ask KYP - Ben he will be one of the best to ask
Edited by RICCA
$50 for a bottom end, $200 for a set of bearings, use your neo head (gives a nice compression ratio with stock pistons), use as much as you can off your current RB (oil/water pumps etc etc). If you can do a lot of the work yourself (read: all of it) then it can be done for very cheap.
There is a guy running 10s in a 33 over east on a standard rebuild and RIPSNZ push some serious power out of standard build bottom ends! Keep the rev limit sensible and it will survive.
Even with a standard setup, I reckon you could slap together a standard build 30 for under $500 and it would be fine with the only large outlay being an ecu.. it will run on a stock ecu but will most likely hit R&R very quickly (mine did and maxxed the afm almost straight away).
You have the benefit of a neo turbo aswell so it shouldn't choke up as early as mine, would probably see you through to 6500rpmish which is good because you don't want the rev limit set much over that.
OK just keep in mind if you use the same turbo you have, you won't get more "power" so to speak.. you will get more torque (or same torque earlier).
e.g. my 30 makes the same "horsepower" as my 20 did, but a lot sooner.. 183rwkw @ ~4600rpm instead of ~6500rpm which makes for a LOT nicer car to drive on the street. The other benefit of more capacity is being able to spool bigger turbos sooner than a 20/25 :P
Don't even need to change the manifold. You can go an internal gate GT30R, will bolt onto stock manifold and be good for 300rwkw. Any bigger and you have to start looking at high mounts etc.
Hell, this is Cubes' engine bay (he's an RB30DET guru in SA), GT30R making 300rwkw and looks stock as a rock!
Injectors, ecu and afm if not going for a map based ecu.
I opted for a GT35R so I have headroom for more power later (also sized my injectors appropriately), but this means I have to go highmount and external gate :wub:
Hrmm Sounds pretty good or
could just save alot of the $$$ and do the the highmount convo i guess
but for now see how i go :wub:
That would be the better way to go about it, even GT30R on stock manifold but still a 25. When the 25 dies then look at a 30 as part of the rebuild, if you're rebuilding your motor there's not much difference at all to make it a 3L :(
if i buy rb30 bottom who would sells rb25 head / intake separate from 25 bottom's??? u'd think not many people would sell separate. could i use rb20 intake manifold and supporting gear???? is rb20 bolt on gear straight bolt up too rb25 top end gear????
If you want your rb20 intake manifold to bolt on then you need to use an R32 RB25DE head, the R33 RB25DET heads have a different bolt pattern.
With an R32 RB25DE head you can use everything off the RB20 but you need to modify the power steering bracket (cut back the top boss so it can bolt onto the RB30 block instead of the head, that goes for whatever head you're using).
Easiest, cheapest, most straight forward swap into a 32 is with the R32 RB25DE head but it then limits you as far as intake options go, there's no GReddy plenum that will fit etc etc. I had to go for a custom plenum.
Edited by bubba
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
