Why Do You need a Z32 AFM?
The Std. Ones with the ECU re-Mapped by Tilbrooks will make up to and over 220rwkw, as they alter the ceiling height of the afm's signal in the ecu.
But why not change it any way, i'm sure it will be limited some where especially with a gt2535. Fullboost around ?!?! 4200-4500.
https://www.sau.com.au/forums/topic/2432-z32-afm/#findComment-44254
Are you serious Joel ? 2535 -- full boost -- 4200-4500 !????! That surprises me i thought it would be sooner than that.
I had allways thought the std afm was maxed out at around 210 or 220 rwkw and iam after if possible 230rwkw as i have all the other gear to do this including nismo injectors. The only thing limiting me with this setup should be the standard internals.
https://www.sau.com.au/forums/topic/2432-z32-afm/#findComment-44367
Basically the Z32 and the R32/R33 is the same size etc appart from the signal that is sent from the afm.
I.e at 220rwkw the afm will send a 5.5v for example where as the Z32 will send maybe 4v.
I'm not really sure but tilbrooks said the AFM isn't a drama as long as the ecu has been re-mapped properly. I imagine that they alter the ECU to read the higher voltages or something..
I'm not 100% sure but I do know that Tilbrooks have made 220rwkw with an rb20det. Std Inj. Std Afm.
https://www.sau.com.au/forums/topic/2432-z32-afm/#findComment-44512
The standard RB25 afm will hit maximum voltage at around the 180-190rwkw limit.
You can still tune a car, but it's a bit of guesswork, because the maps have to be fudged...
The Z32 will give you a better end result, with a smoother power curve, and better mixtures.
matt
https://www.sau.com.au/forums/topic/2432-z32-afm/#findComment-44888
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
