What Is This Thing?
Started fitting a fmic on a r32 gtst today and after the reo bar came off we sat for a while wondering wtf is that thing. Its mounted on the rear of the bar on the passengers side and is the round gizmo with a tube running to an external outlet. Can't find any pictures or any description of it anywhere.
We want to know if we can get rid of it or do we have to leave it because it does something critical??
hmm looks like it might be your flux capacitor
So if we remove it then when we hit warp factor 2 the hyper drive will overload.
Buzzer for alarm?
N\Thanks for the reply but no alarm.
This thing looks to be factory fitted with all the specially shaped brackets and a half dozen bolts holding it on and it would have taken a fair bit of effort to get it into position.
looks a bit like an antenna motor to me or some sort of motor to move something back and forth. What do you think connected to the end of the pipe?
Could also be a part of an undercar flame thrower. Any burn marks at the base of your bodykit?
Exactly!
Hm....Could it be the motor to put the undercar spoiler thing up and down?
as far from what i have seen, some r32's and r33's have the undercar spoiler thing, my mates got the button in his car and the motor in his front bar but its not connected and doesn't work.....well thats my 2 cents
I'm thinking horn too..
was it connected to the car in any other way?
Does your horn work now?
Not a horn. Horn is still fitted and working.
Yes, the thingo is connected to the main electrical loom with 5-6 correctly coloured wires. This is the other thing that makes me think it must be a factory item.
It does look like an aerial motor and the outlet on top of the bumper looks a bit like an aerial housing (with the aerial snapped off) but the tube that connects the two is curved so unless the aerial was very short and very flexible then I can't see how it would have worked. Plus theres no coaxial type cable running from it only electrical wires.
Do 32's have an external ariel?? Ours doesn't, unless of course this is it :D .
Nah not a flame thrower. The only thing burning in this car is $100 notes.
Its a base model car and doesn't have spoiler that moves or any button in the dash.
hit 88mph and let us know what happens
Ah, so thats whats wrong. I keep sitting on 78mph and wondering why the hell I can't go back to when petrol was 60c a litre. Plus I keep hearing this Scotty voice coming from the boot saying "she cannout take the lood Captin". Yes, I have got my movies mixed up.
Thanks for the replies. Becasue no-ones too sure what it could be we've been thinking about pulling this gizmo apart and seeing what it is and what makes it tick but the only problem with that is, what if we need it and can't get the bugger back together.
Will let you know how we get on.
Do 32's have an external ariel?? Ours doesn't, unless of course this is it :bomb_ie: .
OK - what about a retractable parking thingy for short people that cant see the end of the car? You can get them as AM accessories to screw onto a bumper, but I have to admit that I have never seen a retractable one.
ive seen these before, they are off a parking sensor thingy. that would of had a little aerial sticking out of the front bar at some stage and probably disconnected.
Reckon this might be the answer(s). Have removed it from the reo bar but we're more concerned with fitting the fmic at the moment so the thingo hasn't been pulled apart even though dismantling it may not tell us anything.
Am guessing that it did have a short sensor rod sticking up from the front bar but that this was snapped off long ago.
Thanks for the help, will advise if we make any startling discovery which I doubt but you never know.
  • 1 month later...
 Share
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
    • Before and after, headlight's done along with bumper.
