Hey guys,
Has anyone in AUS done an engine conversion of an RB26 R34 V SPEC II NUR engine into a R33 GTR????
I'm considering doing this as i can get my hands on the NUR engine.
after completing the conversion what do you think the car will be worth???
this is a list of mods that i will also be doing to the car if it goes ahead as i have alot of the parts already and or can get a hold of them.
HKS GT-SS Twin Turbos!!
MEGURO Original Computer ROM
BREMBO F40 340 6pot and 322 2pot Brake system!!
OHLINS Suspentions!!
Tomei Oilpan buffel plate
Tomei Metal Head Gasket set
HKS GT-SS Turbo kit
NISMO Sage Tank
NISMO 600cc Fuel Injector
NISMO big capacity Fuel Pump
ATTD Tukada original Oil catch tank
Engine Block Water hole expand
NGK Racing Plug No,8
MEGURO Mainetance Original CPU
(running and setting)
Exhaust;
Mines Silent VX Taitanium Pro
Mines Front Pipe
Mines Super catalyser
Tomei Turbo Outlet
NISMO Intercooler
TRUST Intercooler piping kit
Intakepipe twin air division modification
Exhaust manihold wide modification
Cooling;
BLITZ Racing radiator LMC
HKS Oil cooler
HKS Lowtemp thermostat
SAMCO radiator hose
Garage DEEFEND GT cooling panel
Suspention;
CUSCO Front upper arm
CUSCO Tention rod
NISMO stabiliser
NISMO Rear upper arm link(Front&Rear)
NISMO Rear reinforcemnt A-arm
NISMO Rear member brasekit
NISMO member spacer
Drive;
NISMO Twin Plate clutch G-max Spec2
Body reinforcement;
Do-Luck Rear cross bar
DO-Luck GACHIRI Support
NISMO Underfloor reinforcebar rear
Door section spot weld increase
Breke;
Front BREMBO F40 brake system 340 2-piece brake rotor
Rear BREMO 2 pod brake system 322 rotor
Project mu Type-NR Brake pad
Stainless Mesh Brake horse
NISMO Mater cylinder stopper
Electric;
Ortaneter exchange for new
OPPTIMA Yellow top dry battery
HKS EVC3
Interior;
R34GT-R Front seats(Driver and passenger)
SUPERIOR CARBON look Seat cover(Front and rear)
SUPPERIOR CARBON Center panel
SUPPERIOR CARBON Door panel
Dials;
NISMO 240km with monitor dash(for 400R limited)
With HKS CAMP sytem
Exterior;
ARC rear wing Magic Wing downforce type
Final Motion Front Lip spoiler
(with R33 standard lip spoiler)
Wheel;
Volk Racing LE37 17 inc 9.5J
hehehehe...... just some spare parts i have lying around!
when i'm done i'll be looking at over 500hp atw.
i was considering doing all the above mods to the standard rb26 thats in the GTR but i'll still have to forge and or bore it.
what do you think????
has anyone does this in AUS cause if so i prob wont go ahead with it as i want a one of a kind that will also be worth a bit of money
https://www.sau.com.au/forums/topic/243276-has-anyone-done/
I say stop bragging about all those awsome parts! hehe
to answer your question I havent heard of someone doing it... but it would go bloody well!
one other thing, when modifying, sure it is a good idea to try to choose mods that wont decrease in value as quickly, or that you can get the most use out of, but dont mod for the sake of it unless your going to use it IMO. definetly a cool idea you have, but dont go through with all the work just to try to make your car worth more, enjoy it instead!
https://www.sau.com.au/forums/topic/243276-has-anyone-done/#findComment-4241164
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
