i've noticed that with my car, the rear/passenger side is always 5mm-10mm lower than my rear/driver side (judging by how it sits on the tyres)
is this normal? does it sit level once the car is in "D"rive? ot is it just the uneven ground surface?
any help would be great as its kinda annoying me coz im very fussy.
ps. this is the same with stock suspension + after trying out 2 different types of coilovers
thanks
https://www.sau.com.au/forums/topic/243288-ride-height-issue/
My car is exactly the same maybe slightly lower! Ive had it checked out by two different suspension shops and neither picked up on anything that could be causing the problem! next step is either replacing the bushes (cant seee how this will pick up 10-15mm) or sending the shocks back to fulcrum, shocks are tein super streets, for a look (i hear this is not cheap though!)
if its still got the standard bushes, it wouldnt take much for them to lower it 10mm... you gotta also remember when your hooking round round-a-bouts etc, that your left hand front wheel gets loaded to the max... wearing the bushes faster than the right. its also not a simple strut set up like the s13s etc.. youve got the top control arm bushes, castor rod bushes, lower control arm bushes... all these only need to be give a small amount of play to flog out and sit lower.
its also completly possible that your car has twisted over the years.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
