every now and again i would pull up to a turbo n i hear the BOV go crazy...
"tu tu tu tu tu tu..." lol
i was just wondering if i could do something to my stock BOV on my 32 to make it flutter aswell...
if it can be done, can i please get a quick run down on how to do it...
thanks guys, Michael
Yes it can be done. And no it is NOT the blow off valve making this noise. Ite the noise u get when your bov is BLOCKED or REMOVED.
WHen your car builds up boost and you let go of the accelerator. The pressured air in the system has nowhere to go because your throttle body is closed. Hence the blow off valve vents this pressure. If you have a REMOVED or BLOCKED blow off valve the air will go back through your turbo and out to where your air filter is. The Tututu noise is the turbine wheel "chopping" the air to make that noise.
Best way to do it is to removove the BOV, get an inprint on somtehing of the flange. Get a coke can and cut it open. Cut the coke can into the same size as the flange. THen put the new coke can gasket inbetween your piping and the blow off valve. This pretty much blockes air from going to your bov. You will then get mad VL flutters y0 tu tu tu.
Oooooorrrr you could squash the crap out of your stocker. It will still vent and plumb-back but it will cause your turbo to make the flutter sound when you back off the throttle lightly when on boost. It will vent normally but quicker than usual on sudden throttle lift off....eg. gear changes.
Edited by KeyMaker
lolz i made a block for my mates gtt with some mdf, a rubber gasket, a drill for the holes and jigsaw to cut the shape lolz.
worked a charm but your idea is soooooo much better; why didnt i think of that
God not this shit again...
Why does this get brought up every week.
Speaking of flutter/dose, has any one seen that ignition dvd with the BADWOG R33 (its a pretty old one) and he goes on about wanting the car to flutter?
F**k its piss funny!!
"I wanted a hektik flutter, like a full melbourne spec VL flutter! Its bad for the turbo and its probably gonna blow but its hektik!"
Hahahahaha god that was gold!
its not even weekly mate, its daily... this thread was started 2 days ago ->http://www.skylinesaustralia.com/forums/Sk...is-t243180.html
Now Mr ganbanga.... follow this link... all you need to know...
FLUTTERZ BIBLE
Must be school holidays....
Thats because those people are nobs who want to wreck their turbos. If you want your turbos life to be drastically reduced, get a pod filter and block off the BOV.
Or you could just get the word nob tattooed on you your forehead as this has the same affect.
IBTL
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
