every now and again i would pull up to a turbo n i hear the BOV go crazy...
"tu tu tu tu tu tu..." lol
i was just wondering if i could do something to my stock BOV on my 32 to make it flutter aswell...
if it can be done, can i please get a quick run down on how to do it...
thanks guys, Michael
Yes it can be done. And no it is NOT the blow off valve making this noise. Ite the noise u get when your bov is BLOCKED or REMOVED.
WHen your car builds up boost and you let go of the accelerator. The pressured air in the system has nowhere to go because your throttle body is closed. Hence the blow off valve vents this pressure. If you have a REMOVED or BLOCKED blow off valve the air will go back through your turbo and out to where your air filter is. The Tututu noise is the turbine wheel "chopping" the air to make that noise.
Best way to do it is to removove the BOV, get an inprint on somtehing of the flange. Get a coke can and cut it open. Cut the coke can into the same size as the flange. THen put the new coke can gasket inbetween your piping and the blow off valve. This pretty much blockes air from going to your bov. You will then get mad VL flutters y0 tu tu tu.
Oooooorrrr you could squash the crap out of your stocker. It will still vent and plumb-back but it will cause your turbo to make the flutter sound when you back off the throttle lightly when on boost. It will vent normally but quicker than usual on sudden throttle lift off....eg. gear changes.
Edited by KeyMaker
lolz i made a block for my mates gtt with some mdf, a rubber gasket, a drill for the holes and jigsaw to cut the shape lolz.
worked a charm but your idea is soooooo much better; why didnt i think of that
God not this shit again...
Why does this get brought up every week.
Speaking of flutter/dose, has any one seen that ignition dvd with the BADWOG R33 (its a pretty old one) and he goes on about wanting the car to flutter?
F**k its piss funny!!
"I wanted a hektik flutter, like a full melbourne spec VL flutter! Its bad for the turbo and its probably gonna blow but its hektik!"
Hahahahaha god that was gold!
its not even weekly mate, its daily... this thread was started 2 days ago ->http://www.skylinesaustralia.com/forums/Sk...is-t243180.html
Now Mr ganbanga.... follow this link... all you need to know...
FLUTTERZ BIBLE
Must be school holidays....
Thats because those people are nobs who want to wreck their turbos. If you want your turbos life to be drastically reduced, get a pod filter and block off the BOV.
Or you could just get the word nob tattooed on you your forehead as this has the same affect.
IBTL
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
