Got a misfire. It's most noticeable in 2nd under full throttle and it starts misfiring at about 5500rpm. In 4th at about 5000 rpm full throttle. I'm guessing it's coilpacks. In all other regards she's running fine. I'm sure other gears too but these are the stand out occasions.
Is this likely?
Cheers.
https://www.sau.com.au/forums/topic/243300-misfire/
Is this likely?
Cheers.
i had the same thing last week
Got some splitfires
put em in and problem gone
hope it all works out
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4240487
ANother vote for splitfires, had the same thing happen to mine
PS, hows your gearbox? You got the one from Sydney yeah?
Sounds like the coils then.....I think they're now $625ish. Nissan wants $1,200....
Gearbox is OK. Bit of bearing noise and 2nd synchro could be better. Long way better than my old one, but I'm still looking for the gearbox holy grail.
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4241367
Id check to make sure 110% though before buying.
Simply swap over with someone's who you know works.
You can use mine if you want, they are near new splitfires.
A kind offer. You're quite right as I'm only guessing it's the CPs. Drop me a PM with your number and I'll call to arrange?
Cheers.
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4242240
Oh i know where that is. Look in my sig
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4242334
umm instead of buying new coil packs why not just repair them? and when you have cash get splitfires then.
when i had my 33 repaired it then and never had a problem afterwards. mates GTR33 is putting out 270 atw and was getting misfires like you on full woot did a repair and all is well
my current car R34 GTT 240 rwkw also had misfire and 3 hours to repair and its as good as new.
all you need to do is take it out clean it all up then put a nice thick coat of clear nail polish. i did 3 thick coats on mine and took about 3 hours from taking it all out to going for a test drive.
all it is one or more of the coil packs have a fine fine hair line crack on them so on fool woot the sparks archs out of it causing it to misfire.
its very easy to fix and is a cheap alternative while saving up for splitfires.
ta
Ash
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4244948
ta
Ash
Thanks for your input Ash but I think I'll go for a more robust and permanent solution. The CPs are now 18 years old and I can't be fugged going on my next all too rare drive to miss out on my fun because my....erm....wife's nail varnish didn't do the job. Glad your trick has worked for you though.
https://www.sau.com.au/forums/topic/243300-misfire/#findComment-4245588
  • 1 month later...
