Vehicle 1989 NISSAN SKYLINE HR32 GTS-T
Price $12,000 negotiably or swaps
Kilometres 193,000
Body 2 door 4 seat COUPE
Colour Metalic Black
Interior Colour Black/Grey
Transmission 5 speed Manual
Drive type Rear
Engine 6 cylinder Petrol Turbo 2.0L (1998cc)
Reg Plate BB925Z
Reg Expiry JAN-2010
Road Worthy Certificate N/A
Vehicle ID 6036793
Brief Comments 172rwkw full remap. Goes great. Remote start python alarm. Price drop $12,000 need it sold
Great example of a tidy well maintained r32 gtst. Engine hasn't been opened up at all so completly stock inside. Was resprayed while previous owner had it i don't know who by but it is a black colour with a very nice heavy metalic in it looks very nice when clean.
ENGINE & DRIVELINE:
Standard RB20DET
Front mount intercooler with chrome piping.
New chrome/red plumb back blow off valve.
New turbosmart single stage boost controller.
New saas racing pod filter with chrome adapter to suit.
New 3inch mandrel bent stainless steel cat back exhaust.
Aftermarket dump pipe.
Big Walbro fuel pump.
New genuine nissan alternator less than 1,000kms old.
New water pump less than 5,000kms old.
New irridium spark plugs 10,000kms ago aswell as oil, filter, all new belts for the alternator, power steering pump and air con.
New secondhand airflow meter.
Standard ECU but has had full remap and dyno tune with 171.8rwkw.
New heavy duty clutch about 12 months ago.
BODY WORK:
Has GTR body kit, front bar (minus lower skirt) side skirts and rear pods but still has GTST rear wing.
17inch chrome wheels with near new tyres and lock nuts.
Dark tinted windows.
New gear knob.
Has a set of HID xenon series head lights in the low beams.
Has got a full python alarm system with central locking, shock sensor, remote star and turbo timer functions in built and outputs for extras like auto windows up feature if additional module is fitted.
Has two greddy gauges on left of dash cluster, one fo.r boost and the other for oil pressure and a guage for ol temp. All work including the existing guages in the dash cluster.
INTERIOR:
Near new CD player.
Front 6.5inch pioneer speakers i the front.
Kenwood 6x9inch speakers in the rear.
Selling to purchace new car.
May consider swap for something of interest.
Any inquiries welcome.
Please contact via my mobile on 0407210142
Seller Details
Name Mathew
Suburb gawler
State South Australia
Post Code 5118
pictures are at:
http://carsales.com.au/used-cars/private/N...4&trecs=106
Edited by moscow
https://www.sau.com.au/forums/topic/243326-adel-fsswap-1989-r32-gtst/
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
