  • Replies 327
Auto has it's advantages...
It leaves the left hand free to entertain the passenger :huh:
I just hope he's not bringing a guy :huh: Then he may as well be playing with a gear shifter :D
:down: PG PEOPLE hahah jk, Just learn how to do clutch less shifting....prob mess up your synchro but at least you'll keep your lady friend happy with out the compromise of an auto hahaha
His name is Calvin :)
So you coming along Lauz?
LOL!
Nice list JamesK.
Haha thanks looks like it's going to be pretty big, good thing were not doing on street parking on st. kilda....that would suck
dont have cb - but will try and keep up with everyone, if not i just turn and go home
:P "Try and keep up" - Just put a turbo in your Jazz and you'll be right :D
On a serious note, I don't have a CB either. How important is it? I might be able to get one off a mate, but I highly doubt I'll lose you guys... especially if there's a map supplied.
Edited by jezza boii
nah bringing the r33, jazz is only for work :)
just so if anyone runs into trouble or gets lost then the group can be informed. its not important to have one, but its very good to have and...... NO map supplied :P
    • Don't turn down the limit yet. Put a mechanical pressure gauge on the car in the same spot and go and prove it.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
