Close Thread! New Thread Opened
LEANBAC
 Share
  • Replies 327
Auto has it's advantages...
It leaves the left hand free to entertain the passenger :huh:
I just hope he's not bringing a guy :huh: Then he may as well be playing with a gear shifter :D
:down: PG PEOPLE hahah jk, Just learn how to do clutch less shifting....prob mess up your synchro but at least you'll keep your lady friend happy with out the compromise of an auto hahaha
His name is Calvin :)
So you coming along Lauz?
LOL!
Nice list JamesK.
Haha thanks looks like it's going to be pretty big, good thing were not doing on street parking on st. kilda....that would suck
dont have cb - but will try and keep up with everyone, if not i just turn and go home
:P "Try and keep up" - Just put a turbo in your Jazz and you'll be right :D
On a serious note, I don't have a CB either. How important is it? I might be able to get one off a mate, but I highly doubt I'll lose you guys... especially if there's a map supplied.
Edited by jezza boii
nah bringing the r33, jazz is only for work :)
just so if anyone runs into trouble or gets lost then the group can be informed. its not important to have one, but its very good to have and...... NO map supplied :P
If by top secret you mean fluffy pink dice from the rear view mirror and a penis holder to put your cawk in whilst you drive a girls car :P
i will slap you on your face with my cawk
 Share
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
