  • Replies 327
oh i wasnt referring to that. i can guess what happened. i was just calling you ghey
Sif ghey.
Hmmm weather not looking too good for thurs. Hopefully the showers are earlier in the day.
if the camera is good and a bit of lighting.
should be able to get some awsome photo's in the rain .
i'll be happy with any photo's. only got driveway pics, not that good with fence's and a garage as the backdrop !
how much people u got so far??
i should be able to make it down depends if i can afford petrol =[
Come along man! I've got $50 in my account to get me through til next pay day :down: If I can afford to make it I'm sure you can.
No duck ay..
I guess I'll decide on the day if I'm coming
Dezz you are so coming.
hi guys, no go for me now
eMsta your shit! :D
LOL! Nah, nah jokes! :D:down:
Whats excuse this time... Haha!!
hmmmm are you bringing your friend? as you know '' this '' is a friends an family event :)
Sooo, are you bringing your friend...
You know how she is and you know what Im talking about. '' This '' is a friends and family event ;):(
Petrols cheaper atm.
Fill it up and come on down!
lol i got 40bucks to last me the week to work and i dont get paid till sat =[.
and my friend took my car out for a spin without asking and came back with my front bar destroyed =[. will patch up but wont look nice if u guys are taking photos =p
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
