  • Replies 327
We'll see...
Yeah like, just come out already will ya... LOL! ;)
Nick, u coming to the cruise?
Hey man are you in St. Kilda on that day?
Me and Matt are meeting up you coming along?
Nick wont have license by then.
Visited Alex today to check out some of his new beasts and he said he will bring one of his cars to the meet on Thurs (Hopefully the NuR or GTRHKS ;) )
Hell yeah!
I told Tim to come down with the Nur.
Still want Han to come out with his S-Tune tho...
Did you see the Veilside they got?
Yeap, we can meet up @ Albert Park pitlane or something
Yeah cool Pm ya Thursday.
Nuh man the veilside wasn't there. They sent it away for a tune. Alex said there was something was up with it in the higher revs.
When the car came to Sydney, it 1st came with a HKS F CON V Pro, apparently no one can tune it here in Melb, so they put in an APexi Power FC / Dejectron in.
When you "Slowly" rev the car up to 6000 Rpm, it "Jerks". Something to do with the Vacuum build up and how the way Veilside tuned it, but when you hammer it up to 6000 Rpm and change gears, there is not problem. This only happens in 1st gear tho. The way the cars tuned, its pretty much full throttle all the way in 1st.
haha yea Alex told me the whole story behind it. Apparently it can only be tuned in sydney or perth lol
Nooooo, the hot girl I was bringing canceled due to some school commitment :)
I hate it when people pull out at the last minute.
I will try my hardest to find a replacement chick for the night :P
No matter what though, I'm in for sure. Wouldn't miss it for the world :wub:
You see the problem with the 4/15-7 Spartan weapon is that you have to either turn the weapon its self around for use of the grenade munitions... ...Or turn your back on your enemy and launch your grenade... ...But the problem there is you might hit yourself in the shoulder...
In other news... ...I can't remember if I said I wasn't coming to this or not...
And I'm too lazy to look back through the pages...
Yeah... ...And it still isn't right... ...I've got this strange looking grey ring that fell out... ...Looks like it broke off somewhere... ...but I don't know where... :P
It will be at RE on Thursday...
lol, thats odd, spose to be getting mine back tomorrow, if so i'll leave the mag with ray, if not, i'll give it to you on thursday
said you cant due to your car no working right
Guest
    • No no, sorry I think I made you misunderstand. I have this Tee as well as the lines that go from there. What I am missing is the banjo bolt that connects this line (OEM turbo oil supply line) To this hole, this line is mounted on the turbo and reaches around it so you have easy access the oil and water supply being rerouted to this dual banjo port in the front. like this
    • Nothing at the moment as previously there was a crappy braided line going from engine block directly to the turbo. I have bought a used OEM hardline for the turbo oil supply, which goes from the engine block to the marked hole. I don't have any of the OEM banjo bolts for oil except the one at the block.
    • This is the tee No specs on the page I grabbed it from, out of stock there anyway. But it kinda looks like a 1mm pitch. Would not think it's going to be 0.75mm pitch.
    • OK, I'm with you now. The outlet of the tee that is banjo'd into the block. Dunno what it is, will have a scratch around. The M11 question is.....messy. The minor diameter of an M11x1.0 male thread is 9.917mm. This is smaller than the minor diameter of a 7/16"-24 UNS (which is 10.08mm). The M11 major is 11mm. That's smaller than the major on a 7/16"-24 UNS (which is 0.4375" or 11.1mm) so an M11x1 bolt should pass on the major side. The pitch of a -24 thread is 1.058mm, which is really close to the M11x1, so it should go in at least several turns. I would expect M11x1 to be loose in a 7/16"-24 UNS, at least until enough thread are engaged to make it stop screwing in, if that can happen. Probably wouldn't happen on such a short bolt as you're looking at on the oil tee. Keep in mind that 7/16"-24 is NOT a standard/typical 7/16" thread. Standard is 20. That's the UNF or fine thread. -24 is really fine. I imagine that Garrett chose -24 for the turbo housing oil inlet to get the number of threads engaged up. I would not expect Nissan to have an imperial (UNF, etc) thread on that tee. I would expect it to be metric (if it is a bolt thread) or BSP (actually the Japanese equivalent of BSP) if it is a pipe thread. Given that it's a banjo, it's going to be a bolt thread. If it looks like an 11mm will go in there, then 11mm seems likely. It is very possible that some clown has stuffed that thread by trying to jam some imperial "near equivalent" into it, perhaps with those hoses of yours. Got verniers? Measure up the threads on the hoses.
