Have not got pics but its not too hard.
-With the internal trim (if you have it ) removed you should have the back of the tail light area exposed.
-In the corner against the guard is two (10mm i think) nuts with a bracket that the trim clips onto. Undo these on both sides.
-looking were the boot latch is (on the inside oposite the 'skyline' logo of the bar) there is 4 bolts (again 10mm i think) 2 of which have a little plastic clip holding the wireing loom, remove said clip and undo bolts. That should be all on the inside (from memory, but have a look around incase i missed some)
-Remove numberplate, remove then unplug revese and number plate lights and also the bolt that hold the number plate holder down (if its there)
-looking under the car there should be a single bolt (again 10mm) on the left and right side were the end of the bar meets the guard, closest to the wheel, undo these.
There is 4 bolts holding the tail light in from memeory (2 top, 2 bottom) have a look will be easy to tell and then just the glue stuff.
That should be it from memory takes no longer than 10 mins or so.
Cheers
Ross
Edited by Boss-zilla
