for sale are my beloved te37's from my gtr.
all wheels are immac bar 1 slight 2cm scratch, NOT a rash or scrape, a scratch that jus took some bronze colour off, no idea how it got there lol
275/30/19 good year tyres @ 70-80% tread, still really good
pics are on my car atm, i havnt taken them off yet, replacing them this week/weekend with some 20x10.5 +-0 meisters :D
$4700. free freight aus wide!!
ill try get individual pics as soon as i can
thanks
https://www.sau.com.au/forums/topic/243354-volk-racing-te37-19x105-12-bronze/
here r pics i took today, didnt get a chance to clean the wheels or take em off!! but as i said thy all imac bar 1 with a slight scratch.
wheels are located in sydney
Nice? Are you on crack? That is THE best street R34 I have ever seen. When are you going to show the engine bay, Novak?? :bomb_ie::(:D
haha thx.
im dressin the engine bay up a little, here is a BEFORE shot, ill have the after shot next week wen its done!! polished the turbo, carbon air guide, hypertune plenum, fuel rail, air box, few little other thngs from them , oil relocater is moved, just few little aesthetically pleasing things! so ye should be good wen i get it back FINALLY lol
then maybe motec it haha get rid of the fcon.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
