Alright well i own a Y31 cima with the VQ30det now the engine is not running the best so im thinking about replacing the motor now has anyone droped in a rb25det into one? or a VQ pretty much anyone got any info on engine swaps so i can get a idea of what i may do
only thing is engine must stay auto as this is my daylie and i got a manual fun car so i would like to keep this as is
https://www.sau.com.au/forums/topic/243368-y31-engine-conversions/
it stuttering no smoke at all just stuttering like a bitch it has new plugs could it be the ignitors? or maybe just a bad batch of fuel due to car sitting around for a long time?
i have sorced a rb25det auto for it if i do decided to change engine but would rather save the cash and get this working
I would look at ignitors....I pulled them out of mine and all the carbon rods were totalled.
Otherwise put some F10 fuel treatment through ya car aswell if it has been sitting for a bit.
I would love to do a VQ30DET conversion to mine...I was also thinking about putting in the twin turbo VG
Alright a bit of a update
i got the coils on order spitfire ones i will await those to come then im going to drain the fuel and put a fresh 10L in (enough to get it going and at least drive it to a petrol station LOL
i think two of my air bags are gone how ever so i will ether have to find used ones that work or go aftermarket air bags as i dont want coilovers
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
