The other day I was cruising around all of a sudden, my car started to shake while idleing at traffice lights, and as I was taking off had little to no power at all. The orange error light or whatever it is came on, and so I shit myself and proceeded home. I turned my car off and was gonna check it later, so I turned it back on after and it seemed normal again... this has happened 2 or 3 times since, while driving to and from uni... car shakes while idleing and loses power when it comes to taking off...
anyone have any idea what the problem might be?
https://www.sau.com.au/forums/topic/243456-shakingloss-of-power/
I had the exact same problem for months. So I came to this forum and asked for advice, I was told it was the coil packs and after I changed them I've never had that problem again.
When the problem occurs, see if you can park somewhere and turn off the car for 10-15seconds. Start it again and it see if it runs properly.
Edited by Dany
Yeah I do that, and sometimes it works.... hm what coil packs did u change urs to?
oooww this happends to me in my R33 also... well when i am coming to a stop i will have clutch fully pressed in and whne the revs drop to the idle amount it sometimes drops lwer then comes back up to idle, however occasionly when it drops it goes to low and just stalls so you have to start her up again... it all sounds fine and runs good before and after it just a random thing that happens.... And im yt to figure out why lol
this happens to me every now and then too...
seems to not happen when i have a full tank of fuel though. im thinking its my fuel pump.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
